Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 07-13-2019, 02:14 PM
briaboy briaboy is offline
Default Aux channels - still hearing the input tracks?
Hi - using PT 2019.5 with UAD Apollo 8 interface - I've routed all my drum channels to an aux channel (drum bus). For playback and mixing, I just want to hear the drum group aux channel, but the input tracks are still audible. If I mute them or adjust the volume, the aux channel also mutes or adjusts in volume. Am I doing something wrong here? Thank you!
Old 07-13-2019, 02:38 PM
BScout BScout is offline
Default Re: Aux channels - still hearing the input tracks?
Sounds like you have them grouped.
Or you've turned the "All" group on by mistake.
Lower left side of the edit window is where you look.Hopefully you can see that pane, if not, you need to find the small arrow on that side and click it to reveal the side panes.
Old 07-13-2019, 02:47 PM
Well, I have all the drum tracks routed to the drum bus, that's all (I think!).
Old 07-13-2019, 02:57 PM
So, no, they're nor "grouped" in the sense that you mean. I can still operate the individual faders independently. I just don't want to hear the input tracks, only the aux drum bus.
Old 07-13-2019, 03:02 PM
Post a screenshot of your mixer page.
The terms you are using are confusing the matter so it is just easier to look at a mixer's routing to figure out what you've done.
Also, is LLM on? It should be off if you aren't recording.
Old 07-13-2019, 03:07 PM
Sorry, what's confusing?! The Aux channel is my drum bus, and routed to that drum bus are the individual drum channels.
Old 07-13-2019, 03:40 PM
"input tracks"
No such thing. Tracks have inputs (multiple types of tracks have inputs.) If you mean an audio track with input enabled that means something. If it is an audio track that has your recorded file and no longer input enabled, that means something. An aux track has no audio. You can't solo an aux and hear anything unless the incoming tracks routed to it (with audio files) are solo safe and the aux is input enabled or the input to an aux is a physical input.
Groups are groups. They mean one thing in Pro Tools. And you can have groups where faders move independently.
You can have audio tracks routed to more than one output.
I could go on. But it is easier just to look at the mixer page which clearly shows what you've done verses using imprecise words.
Old 07-13-2019, 09:24 PM
amagras amagras is offline
Yes, a screenshot and we would know for sure what's the problem
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 07-14-2019, 07:12 AM
To be clearer, I have created an aux track. That is my drum bus. I have routed kick, snare, hihats and toms channels to that drum bus. When I hit play, I hear both the original individual channels AND the drum bus. I just want to hear the drums as a group, not the individual channels. How do I do that?
Old 07-14-2019, 07:24 AM
Here's a screenshot!
Hearing all tracks in scrub and shuttle clgood Artist Series 3 12-08-2014 07:08 PM
Hearing recorded tracks while recording Durstlaw FireWire & USB Audio Interfaces (Win) 6 03-19-2014 11:44 AM
MIDI Input from keyboard, lag before hearing sound danjfoley Windows 3 01-13-2014 01:55 PM
hearing midi tracks through mbox pmclellan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-18-2005 08:44 PM
Problem with hearing certain tracks..... connelldestructo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-09-2005 07:16 PM
