Fast Track C400 input question
Hello,
I have a Avid Fast Track C400 here which should have 4 inputs. Im using a Yamaha AN1X connected to it and works fine using either the front or back parts. Soon however I will be buying a virus C, which I want to be connected simultaneously. But how does this work? I mean theres 2 mic inputs on the back and 2 'instrument inputs' on the front. But I can only pick one of those is that correct? The front/rear button either activates the front ports or the back ones. How do i use them all 4 at the same time if this is possible? Thanks in advance, Dharion |
Re: Fast Track C400 input question
Your 3 and 4 inputs are the L/R SPDIF inputs. I don't see SPDIF out on either the Virus C or the Yamaha, so I don't think you'll be able to connect both at the same time to a C400..
Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
Thanks for the quick answer. Ooh damn, so those 2 inputs on the front and 2 on the back cant be used at the same time? Indeed no spdif on both devices.
The inputs on the front are instrument level inputs 1/2, the inputs on the rear are mic/line level inputs 1/2. The input source (back panel Mic/Line, or front panel Instrument) is chosen using the corresponding Front/Rear Input button for each channel.
Joel
Oh okay so that means they can't be used simultaneously. Then I know enough. Thanks :)
M-Audio Fast Track C400 | Dunkin1953 | FireWire & USB Audio Interfaces (Mac) | 2 | 03-15-2016 09:49 PM |
Fast Track C400 generates too much noise at instrument input, noisy amp simulation | TLap | FireWire & USB Audio Interfaces (Win) | 0 | 10-15-2015 12:35 AM |
Fast Track c400 headphone stereo question | thesh | FireWire & USB Audio Interfaces (Win) | 2 | 09-25-2015 04:19 PM |
Fast Track c400 | Suddenly Clear | Pro Tools M-Powered (Win) | 3 | 10-29-2011 02:17 PM |
Input question using Fast Track Pro | mam219 | Pro Tools M-Powered (Win) | 1 | 03-09-2008 12:41 PM |
