Old 02-08-2010, 05:50 PM
AdamPT8 AdamPT8 is offline
Default Auto Input monitoring / Input only monitoring - Alt+K
Ok, I know there are a lot of threads on this, I've read the pro tools manual and stuff online regarding this but I still can't figure it out.
It seems to me that whether input only monitoring is selected (green light lit up) or not, exactly the same happens...
I can only monitor by having the track in record ready so therefore I can't monitor bass whilst recording drums without recording the bass as well, for instance.
It seems so stupid that Pro Tools have done this.
Pro Tools LE 8 by the way.
Old 02-08-2010, 06:40 PM
Larold Larold is offline
Default Re: Auto Input monitoring / Input only monitoring - Alt+K
You have to have an HD rig for that to work.
Old 02-08-2010, 06:42 PM
Actually, I think you could put the bass in an AUX fader and hear it the way you want....
Old 02-09-2010, 04:37 AM
So stupid having to do that though, it is a feature that is present on all analogue mixers and every other DAW, why Pro Tools have chose not to do it is beyond me.
Old 02-09-2010, 08:28 AM
bennym bennym is offline
Actually, the point is that it allows you to listen to a record enabled track whilst playing the session, but not recording, since it normally would "mute" that track if you didn't go into record.
Old 02-09-2010, 10:50 AM
msawitzke msawitzke is offline
The Aux solution works. You can monitor a track input while playing back. I use this for talkback all the time. It'd be nice for Digi to add the input monitoring HD has, but I doubt it'll happen any time soon, if ever.
Auto input/input only monitoring failing in PTLE 8.0.4 miketeachesclass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-11-2012 08:48 AM
Auto Input Monitoring - how to visually tell it's on? awritersparadise Pro Tools 9 3 10-20-2011 03:10 PM
auto input monitoring sometimes doesn't work jntracks Windows 3 04-18-2011 03:06 PM
auto input monitoring issue jntracks Windows 10 02-07-2011 05:37 AM
Auto Input Monitoring? Punching GrahamCA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-28-2002 04:39 PM
