Old 10-13-2017, 01:32 PM
vlakanas vlakanas is offline
Default Send mix to Portico Master Bus II, rtn to PT
I want to get my mix, from PT, into Neve Portico Master Buss II, back to PT. Then the last touches of mastering.
Im using two UAD silver face Apollos.
called UAD, got two different takes and the last tech basic wished me good luck on the weekend. My first bad experience with UAD. Nice!
One tech mentioned cue's and inputs ,outputs . The last unhelpful guy, something about I/O's and something. But its not an insert. Is it?
HELP!
Anybody?
Thanks
Peter
Old 10-13-2017, 02:47 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Send mix to Portico Master Bus II, rtn to PT
Not very clear what you want to do....
There is this....
https://www.youtube.com/watch?v=6RhpXMvPY4E
Not exactly what you want but this is helpful
https://www.youtube.com/watch?v=nN9aqrugchg
Daniel
Old 10-13-2017, 03:45 PM
Dan IceWood Dan IceWood is offline
You set it up as a hardware insert.
Refer to the PT reference manual on the procedure.
Old 10-14-2017, 05:08 AM
HELP!
Anybody?
Thanks
Peter
The UAD people were probably trying to get you to go down the road of instead using an insert to just come out of PT on a stereo pair, through the Apollo to the Neve, back to the Apollo and back into PT with the ins and outs on the same pair. IOW if you go out outs 3/4 you come back in on ins 3/4. That's what I would do, particularly if your version of PT doesn't do h/w inserts.
Jack
QAPLA!
Old 10-14-2017, 05:19 AM
Drew Mazurek's Avatar
HELP!
Anybody?
Thanks
Peter
Peter,
PM me with your contact info and I will get you the direct help you need from UA.
www.drewmazurek.com
Old 10-16-2017, 02:06 PM
Check your email Peter.
www.drewmazurek.com
Old 10-17-2017, 10:11 PM
Thanks guys. Working on it. Think I got it.
Let you know soon.
Old 10-22-2017, 07:54 AM
Nope. Don't get it.
I have bounced , the mix, on a separate session.
I have some eq's (Plug ins)on the track , as inserts.
Im sending this session to an aux track.
On this aux track, Im placing the Hardware, Neve Portico Master Buss 2, as an insert.
Line 5-6, out from the UAD Apollo, into the Neve.
Out from the Neve, into Line 5-6, of the Apollo.
Now what?
Thats where I am.
Sending this message also to UAD.
Any ideas?
Thanks
Peter
Old 10-22-2017, 08:54 AM
Nope. Don't get it.
Now what?
Thats where I am.
Any ideas?
Thanks
Peter
Being you're coming out of PT to the Apollo to the Neve and back from the Neve into the Apollo and back into PT do NOT set the Neve as an insert. When the signal comes back into PT assign it to an audio track set to record. When you hit the record button that audio track will record the path I just wrote about.
Jack
QAPLA!
Old 10-22-2017, 10:06 AM
When you say assign, meaning what? The input on the track , to be recorded to as example, line 5-6, from the Apollo?
This way I can listen to what is going through the Neve.Correct?
Thanks
How to control send MUTEs with VCA master? eurovision Tips & Tricks 1 11-13-2014 11:06 AM
What format to send master out on. RandyPokeda macOS 7 10-19-2012 09:12 PM
Rupert Neve Designs Portico II Master Buss Processor Patheticus Buy & Sell 1 06-22-2012 12:31 PM
Send it all to Aux before the master? studiojb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 04-28-2007 10:03 PM
About to send project to master/replication MR808 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-09-2004 06:35 AM
