Cumulative RMS Meter?
Is there such a beast? Lots of integrated readouts for LUFS for broadcast and such, but the only RMS meters I have are strictly realtime. I'm editing an audio book, and my RMS meters seem to show generally 2-3dB higher than my LUFS (LKFS), but I'd like something a little more accurate. My extensive searches have been fruitless. Is this a quest of pure folly?
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7 |
Re: Cumulative RMS Meter?
Hi
Before the general availability of loudness plugins I used to use Audioleak, which is very comprehensive offline metering tool. It will create a rms graph and overall average. |
Thanks, this looks useful. Since there doesn't appear to be an AAX plugin that will do this, standalone looks like the answer. With all the sophisticated metering options today, I'm pretty amazed at the difficulty of measuring RMS.
RMS is not as accurate as LUFS.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Understood, and because I do a lot of work for broadcast, I'm comfortable working that way. But ACX and other on-line audio and video distributors often give audio specs in RMS averages, and I'm concerned over the translation. Kinda OCD, ya know.
Hi Sean,
From my experience, when they state "average RMS" (which is as ambiguous as it gets) they mean "the rms meter moves around x dB" during realtime playback, not a mathematically accurate average. I've seen many nonsensical specs during my life, and one has to read between the lines sometimes and apply common sense. For example a RMS total average over one hour would include the pauses in the calculation, resulting in an artificially low value, compared to what you see on the RMS meters when you speak. On the other hand, LUFS uses some perceptual weighting which can make the figure lower than RMS, as you experienced. Considering the dynamics of an audiobook is fairly narrow, I would just keep an eye on the realtime rms, adjust master gain as needed and stick to a comforatble monitoring level. |
why external vu meter/ plug-in vu meter differ? | sjtae | macOS | 8 | 06-06-2012 05:50 PM |
Inserts affecting send meter but not channel meter? | Kbrinson85 | Windows | 1 | 05-01-2012 07:00 AM |
Are the cs updates cumulative? | guitaro | Pro Tools TDM Systems (Mac) | 2 | 03-11-2008 11:17 AM |
23.976 cumulative errors | schiffdigital | Pro Tools TDM Systems (Mac) | 5 | 04-10-2005 04:00 PM |
mbox cumulative digital noise | jimkonczyk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-26-2004 02:04 PM |
