Old 01-27-2008, 09:23 AM
gryphondale gryphondale is offline
Default Strike 1.5 upgrade - not working because of iLok-working now
Hi everyone,
I just downloaded the new Strike upgrade. Now when I start Pro Tools, it tells me I have to register. I click the BUY button, and then it tells me that Strike is not authorized on the iLok. HOWEVER, I go to my iLok and Strike is there.
There is NO documentation on how to update the iLok to the new version. How do I do this? Has anyone else run into this?
Thanks for your help!!!!
UPDATE::::::
I called Sweetwater Tech support and they helped out tremendously! It was a problem with my iLok, not the software upgrade. The drivers had gotten corrupted and Vista did not recognize my iLok, so I simply had to uninstall, remove the iLok, reinstall the drivers, and after a final restart, plug the iLok back in.
Thanks!!!
Dale
Anyone get Strike or Structure V2.0 working? DetroitT AAX Plug-ins 40 10-30-2013 01:51 PM
strike and transfuser not working ilulilu888 Virtual Instruments 1 08-27-2012 07:36 AM
HELP! Strike not working properly! Compression Records Virtual Instruments 3 07-10-2008 09:28 PM
STRIKE - WHY ARE PANS NOT WORKING?????? Jim Casey Virtual Instruments 3 04-09-2007 03:29 PM
Strike not working properly GuyPicks Virtual Instruments 6 11-17-2006 01:11 PM
