Old 11-12-2019, 08:08 AM
littlesicily littlesicily is offline
Default ADC not working w/ HDX summing two inputs
When I record el.guitar, I've been trying to use 2 mics into 2 aux inputs, then summing the 2 auxes to a mono bus to a mono record channel.
PT reports "0" samples of latency / ADC but after the re4cording is done, the summed audio file is late...sometimes! It's so unpredictable and frustrating. Is this a known bug or am I missing something?
PT Ultimate 2023.06, Mac Studio Max M2 64GB RAM, HDX, OSX 13.04.01, EuControl 2023.06 w/ Avid S1
Old 11-12-2019, 08:22 AM
clausiii's Avatar
clausiii clausiii is offline
Default Re: ADC not working w/ HDX summing two inputs
why don't you just record on two mono channels with both panned center?
same result sound wise and no routing delays.
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 11-12-2019, 08:25 AM
Yes, but when I have 6 egtr passes, that's 12 tracks...six groups to keep the blend and six more busses to process them. Just too messy. I have been bouncing each pair to disk after recording them discretely but was hoping to avoid this extra step bc ADC is SUPPOSED TO WORK!
Old 11-12-2019, 09:31 AM
XJENSEN XJENSEN is offline
This may be a known bug. Check the Pro Tools Read Me:
Automatic Delay Compensation cannot not be applied to tracks recording from different types of sources (PTSW-157960)
Automatic Delay Compensation cannot compensate for cascaded records that use both I/O and bus inputs to recording tracks. An example of this is feeding an audio track (in record) from an audio input, and then bussing the output of the track to another audio track also in record. The first audio track will be compensated but the second cascaded track will not be. (This is not a common workflow.)
This looks a bit like your workflow.
Old 11-12-2019, 09:33 AM
My situation is a bit different.
two live aux inputs > mono buss > mono record track.
Old 11-12-2019, 09:59 AM
ZEUSS ZEUSS is offline
I don't think that's the scenario he's describing.
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1
Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX.
Old 11-12-2019, 10:01 AM
You're right. I read his response too fast.
My situation is two live aux inputs > mono buss > mono record track.
Old 11-12-2019, 11:22 AM
Well, I said 'This looks a bit like your workflow.'
The point being that as soon as you get an intermediate aux or bus in between, PT can no longer properly manage ADC. This pops up in a lot of alternative workflows, believe me, and I hope is a feature they will properly implement very soon.
ADC currently only works properly in all but the simplest scenarios. Don't go side-chaining or bussing arround..
Old 11-12-2019, 07:16 PM
Correct. But In his scenario it’s supposed to work.
Old 11-12-2019, 09:18 PM
YYR123's Avatar
YYR123 YYR123 is offline
Supposed to yes, but doesn’t
He has to change his workflow to get anything done, yes it’s a drag but the other options are don’t get anything done and or get another daw.
That description of the readme sounded like basically anything Deeper than just main track recording is problematic
I would trash prefs and try again.
If that didn’t work I would downgrade to the last know version that was working and Park it there
I am running 12.5.2 for this same reason, I just need the stuff to work - I don’t need the latest bug infected release
Daniel
Inputs not working Weenerdude Pro Tools 2018 1 12-26-2018 11:28 PM
Mic Inputs 1-3 not working since PT8 cqd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-09-2009 08:14 AM
Mic Inputs Not Working. ghost104 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-15-2007 07:04 AM
pro tools summing or digital board summing kingz Pro Tools TDM Systems (Mac) 9 04-29-2004 12:46 AM
Summing two mic inputs to one track. losttimestudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-28-2004 12:16 PM
