Old 09-12-2012, 07:36 AM
Borgbilly Borgbilly is offline
Default Clip Gain Line on D-Command?
I would very much like to have a soft key on my D-Command to switch the clip gain line view on and off. There is no keyboard shortcut for this feature that I am aware of. It seems the only way to access this feature is to pull down the View Menu and switch it with the mouse. Any chance that could be added to the soft key function set with a future firmware upgrade?
Richards Outpost Audio
* Ain't Life Grand?*
Old 09-12-2012, 10:15 AM
Stig Eliassen's Avatar
Default Re: Clip Gain Line on D-Command?
I was about to suggest that you'd create your own shortcut in the OS itself (this can be done in Windows too, yes?), but I discovered that the one I made doesn't toggle. I can make the clip gain line visible, but can't hide it again with the same shortcut.
Old 09-12-2012, 12:27 PM
Hanswurstlsepp Hanswurstlsepp is offline
Your friend will be X-keys !
Just did a small demo video.
http://youtu.be/bPBcNO8phK4
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 09-12-2012, 05:15 PM
JR Fountain JR Fountain is offline
That's weird, mine works fine here. I use F1 to toggle the values and F2 to toggle the line using the OS shortcuts (10.6.8).
JR
J.R. Fountain
credits: www.imdb.com/name/nm0288354/
system: Mac Studio Ultra, 128 GB RAM, macOS 13.6.1, MTRX Studio, S3 / Dock, PT Ultimate 2023.12
Old 09-12-2012, 06:18 PM
cjguitar cjguitar is offline
The default Pro Tools shortcuts for clip gain are (in Mac):
Show/Hide Clip Gain Line: Conrol+Shift+(-key)
Show/Hide Clip Gain Value/Fader: Control+Shift+(=key)
Most shortcuts work with clip gain if you add the Control+Shift key, like copy clip gain is Control+Shift+C, etc.
Chris M. Jacobson, CAS
Re-recording Mixer, Sound Designer
IMDB
Old 09-13-2012, 09:43 AM
Nice. Thanks Chris.
J.R. Fountain
Adjusting Clip Gain On More Than One Clip Blank Frank macOS 17 05-15-2015 06:34 PM
AudioSuite Gain/Normalize also on Clip Gain A-n-d-i macOS 0 03-13-2014 12:46 PM
protools 10 clip gain line /volume line alidav Pro Tools 10 3 03-09-2013 05:21 PM
Export Clip With Clip Gain BobbyDazzler Pro Tools 10 0 03-03-2013 03:06 PM
Clip gain on clip groups: bug or feature? idris Post - Surround - Video 6 01-02-2013 10:48 PM
