Old 09-19-2011, 11:36 AM
anotherchrisperry anotherchrisperry is offline
Default 2.6.1 Rotary Encoder Issues, and MC Control Touch Screen Freeze
Since updating to 2.6.1 (10.6.8, pro tools 9.0.3) I've noticed two crippling issues:
1. Touch screen on MC Control (Euph version) often becomes unresponsive. Power cycling unit fixes problem.
2. Rotary encoders "jump" values on both Control and MC MIX when using with dynamics and EQ. All encoders do this, with UAD SSL and Waves SSL (probably others, but these are my go to for mixing)
The value jumps make it almost impossible to use the encoders with confidence.
Anyone else have these problems?
Old 03-10-2012, 08:46 AM
evs evs is offline
Default Re: 2.6.1 Rotary Encoder Issues, and MC Control Touch Screen Freeze
hi,
i have the same behavior with eucon 2.6.2 an pt 10.01 with a brand new control (bought yesterday..)
the ecoders "jump", but its not that bad that they are not usable, but not nice either.. and its just with eq and dynamics..
anyone has a solution for it?
all the best
Last edited by evs; 03-10-2012 at 09:54 AM. Reason: i wrote eucon 2.6.1, that was wrong, i have 2.6.2
Old 03-10-2012, 08:48 AM
jesse p jesse p is offline
Try 2.6.2
www.kdsound.net
Sound for film and Television
Old 03-10-2012, 09:53 AM
evs evs is offline
sorry, my fault, i´m using 2.6.2 allready.
is this a known bug?
Old 03-10-2012, 11:47 AM
likenedthus likenedthus is offline
I believe there are several people with this issue, and from what I've seen so far, none, or almost none, have been acknowledged. I'm having problems with connectivity, myself. I've tried every routing/ip configuration possible, with no luck. In fact, I think the longest my Artist Control unit has stayed connected to Logic is around 5 minutes, which isn't all bad considering it doesn't control some software at all anymore (RME Totalmix, for example). I've since put the unit back in its box.
Old 03-10-2012, 01:23 PM
evs evs is offline
this is really bad..
interestingly i had the same bug when using the novation "nocturn" with automap... so maybe its more like a software bug?
Old 03-12-2012, 12:13 AM
noeqplease noeqplease is offline
Location: Los Angeles, CA, USA, Planet Earth, Solar System, Milky Way Galaxy
Thumbs down Re: 2.6.1 Rotary Encoder Issues, and MC Control Touch Screen Freeze
Eucontrol 2.6.2
Pro Tools HD 10.0.1
Mac Pro Xeon Dual Quad Core 2.8 GHz (8 cores)
6GB RAM
Mac OS 10.6.8
I get the touchscreen freeze after about 15-20 minutes of the unit being on.
Restarting it does not cure the problem.
Rebooting the computer solves it sometimes, but the issue comes back.
Also, I have tow MIX surfaces, in which on both units, sometimes fader no.5 stops sending fader touch commands.
I cleaned all three units really well, and still see the behavior.
WTH Is going on?
Nick Sevilla
nick@nicksevilla.com
Old 03-12-2012, 12:46 AM
robertg robertg is offline
Originally Posted by noeqplease View Post
Eucontrol 2.6.2
Pro Tools HD 10.0.1
6GB RAM
Mac OS 10.6.8
WTH Is going on?
No need to restart the whole computer, restarting Eucon would fix it.. For me, this happens sometimes when I use the assignable knob feature (the screen freezes).. I haven't taken the time yet to re-create a reproducible situation for support
Old 03-12-2012, 11:18 AM
evs evs is offline
i just discoverfed that when i´m using the digidesign EQ3 plug in that the encoders are NOT jumping. everything works as expected.
dmg and wave plug ins seem to jump. i don´t have tried others.
anyone experienced the same?
Old 03-13-2012, 03:10 AM
crustn crustn is offline
Default
@evs: can confirm. The avid plug-ins work much smoother with the encoders than third party plug-ins. It's certainly a software problem! Try recording plug-in automation with the encoders and look at the automation lane.......
MC Control touch screen misreads coords of press Pasz Artist Series 15 12-15-2013 09:07 AM
Artist Control V1 Touch Screen Xill Artist Series 3 08-19-2011 02:52 PM
Touch to select on MC mix, does control touch screen follow? Led Artist Series 0 03-24-2011 06:36 AM
Getting parts for control 24? need rotary encoder pots replacing! crizdee ICON & C|24 2 08-28-2008 05:47 PM
Touch Screen Control Surface? joy4u Tips & Tricks 2 11-30-2001 02:30 AM
