Old 10-17-2020, 03:56 PM
grateful grateful is offline
Default Error message without a number,003 PT8
Hello,
I'm stopped in my track (pun intended) and have a project deadline.
My external HD is where my project files and samples live. It's a Mini Stack Max external drive. It always works without problems.
When I opened my Pro Tools 8.0.3 session I get a pop up with these words:
"Mini Stack Max" is not an audio playback volume.
What should I do now? Can someone guide me step by step?
Thank you,
Grateful
Old 10-17-2020, 04:36 PM
Default Re: Error message without a number,003 PT8
Workspace:Volumes... Set the volume to playback or record depending on what you want.
If all this is greek to you, it's all in the Pro Tools Reference Guide.
Now did the Record/Transfer/Payback settings just get corrupted? Or accidently changed? Or is there something else wrong?
Still problems try trashing prefs.
That not the issue.. is the drive mounted read/write in macOS? (no "rdonly" option shown in the list within the () as when you run the "mount" command in the terminal. Do the contents on the drive look OK from the finder?
Anything else you changed recently?
Any other errors or weirdness?
EDIT: And hopefully you have a SATA SSD in that external drive... but even then I probably would not be putting samples and session files on a shared SATA drive. Not that it will cause this problem..
Way to turn off the message of a dupicate track number? Steve Garman Tips & Tricks 2 05-29-2019 09:16 AM
PRo Tools First - Maxixmum number of project reached error Hoonte Pro Tools | Intro Discussion 1 02-26-2017 07:47 PM
Pro Tools 11 activation error-licensing service not running error message Seismic Sound Windows 5 03-23-2015 05:35 AM
iTune blues: Number nine. Number nine. Number nine. shaggy Pro Tools TDM Systems (Mac) 0 01-31-2001 08:12 PM
Soundfile Error: Invalid Number of Bytes dBgogogo Pro Tools TDM Systems (Mac) 1 01-17-2001 12:03 AM
