Old 05-26-2020, 08:37 AM
Tony Jung Tony Jung is offline
Default Re: Best Tablet for the Dock?
I'm thinking about getting the Samsung Galaxy Tab S6 Lite since its height is 244.5mm. It's almost twice the price of the Huawei T5 but its screen is 10.4" vs the 10.1" on the T5.
Just wonder if anyone thinks the extra screen space is worth the extra cost.
TJ
PT2023 on 2023 Mac Studio M2 Ultra
Apollo X8P & Twin Quad Mk2, UAD Octo Satellite, Avid Dock, Avid S1, Console 1, Digi002, 2016 MacBook Pro running PT2020
Old 05-27-2020, 03:14 PM
freeBase freeBase is offline
Originally Posted by EddieJones View Post
With the new portrait mode I would highly recommend a 12' iPad. I use the 1st gen iPad Pro 12.9. Plenty on eBay.
Amazon Fire 10 does not fit.
The portrait configuration looks sloppy with all the empty space between the edges of the iPad and the actual dock. Is there new thin bezel tablet that fits properly, makes the iPad look "built-in" and lines up to the knobs?
The 10.5" looks good, but the bezel is such a waste of screen space.
Old 11-14-2020, 05:31 PM
MrBibidy MrBibidy is offline
Originally Posted by freeBase View Post
... Is there new thin bezel tablet that fits properly, makes the iPad look "built-in" and lines up to the knobs?
I want to know this too!
James Hurley,
Int'l Freelance Producer & Mix Engineer
http://www.Abravemix.com
Old 01-19-2022, 10:37 PM
Mixmaster Rick Mixmaster Rick is offline
I'm just reviewing this thread and saw the link to the 12.9" iPad in Portrait mode. I just purchased two S1's and a Dock and currently do my plugin editing on my 12.9" iPad Pro in Landscape mode on an S1.
What do I need to change in order to get that Portrait look as posted?
Old 01-20-2022, 05:44 AM
its2loud its2loud is offline
Put it in your Dock and add the tablet as you would for normal Dock workflow.
  #16
Old 01-22-2022, 08:18 AM
Thanks for the follow up.
Do I need to make any changes in EuControl like move a surface up or down?
  #17
Old 01-22-2022, 10:29 AM
I don’t know how you physically have your surfaces laid out to answer that question.
Add the tablets you use as meters on top of the S1’s in EuControl and add the AC tablet that will be physically on the Dock under the Dock listed in EuControl.
Nothing else needs to be done.
The orientation of surfaces in EuControl should be top to bottom of list as the physical layout is left to right.
So. If on your desk you have S1(meters)+S1(meters)+Dock(AC)
Then in EuControl it should be added in this order
S1(meter AC)
S1(meter AC)
Dock
Avid Control
This has generally worked for me.
  #18
Old 01-22-2022, 10:54 AM
I'm still trying to learn EuControl and the impact it has on the tablets. I've attached my current setup. Please let me know if you have time to help. The attachment named "iPad Pro on Right S1" is my current layout.
Best,
Rick
  #19
Old 01-22-2022, 11:03 AM
Default Best Tablet for the Dock?
Follow the order in EuControl as I suggested based on your physical layout.
You’re pictures are showing two different layouts and don’t match EuControl
  #20
Old 01-22-2022, 11:27 AM
Starting that now.
Keep in mind I have the larger 12.9" iPad Pro should that be as a Meter on the 2nd S1 or in Portrait Mode on the Dock?
Suggestion: Users of S3&Dock together: dock fader becomes 5th VCA master fader bassmagnetic Avid S1, S3, Dock and Control App 0 10-01-2016 08:20 AM
can you use a pen tablet with PT? Alex Rodriguez 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 03-30-2008 05:19 AM
ANYONE USING A TABLET LIKE ONE OF THESE? glu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-22-2005 06:07 PM
Tablet for PT on OSX G4? SteveGarman Pro Tools TDM Systems (Mac) 8 09-14-2004 07:57 AM
pen & tablet.... dar Pro Tools TDM Systems (Mac) 16 04-15-2000 12:10 AM
