Old 12-11-2019, 11:26 AM
Larry O Larry O is offline
Default Saving a chain of plugins?
Hi, I apologize in advance for such a basic question, but I'm apparently not clever enough to search the right terms for a definitive answer.
In Win 7/PT 10 I commonly use a number of plugins in my master buss. These may be several instances of EQ, compression, bx solo, Tape, Maxim, etc. I have created and saved a plugin setting for each effect but would like to know if I can save and later quickly order up the same plugins.
Possible, or no?
Thanks
Old 12-11-2019, 11:36 AM
Sardi Sardi is offline
Default Re: Saving a chain of plugins?
Possible, or no?
Thanks
Track presets is what you’re after.
Old 12-11-2019, 12:40 PM
Exactly^^^ Check out youtube for some videos showing the hack as its well-known and really a great thing.
Old 12-11-2019, 02:16 PM
No need for the workaround. It was added as a feature in PT2018.
EDIT: Just realised the OP is on PT10. The workaround is the only way to do it on that version.
Old 12-11-2019, 02:40 PM
amagras amagras is offline
Save all your chains as a template/import from (alt+shift+i) and select the chain you want to use
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 12-11-2019, 03:30 PM
Thanks, I followed one of the several online tutorials, created the folder/file name, added the "t" to the extension, but still no joy. I thought perhaps I was placing the track presets folder into the wrong place, so I added it to every Avid/Pro Tools folder in my laptop, lol. It's not that big of a deal I guess, thanks for the direction. Maybe this feature doesn't work in Windows?
Old 12-12-2019, 10:21 AM
Just an update; I did get this to work in Win 7/Pro Tools 10. My error was that I did not create sub-folders and was simply putting the ptxt file in a "track presets" folder. Appreciate the responses and guidance.
Blue Cat's MB-7 Mixer 2.5 is here - with ext. side chain input for hosted plugins bluecataudio AAX Plug-ins 10 05-13-2015 01:38 AM
Waves Plugins Settings not saving arnisteinar Pro Tools M-Powered (Win) 2 12-23-2012 03:34 AM
Chain Together Plugins As Preset? lowoctave 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-05-2007 01:59 PM
Saving Groups of Plugins? roainfo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-08-2007 06:52 PM
Saving Plugins Settings to session folder Legs Pro Tools TDM Systems (Mac) 0 09-26-2001 09:37 AM
