Old 09-25-2009, 03:56 AM
Simmer Simmer is offline
Default Assertion in ... line 199
Hello there,
when trying to import a file via AudioEase Snapper to the Session bin I recieve:
Could not complete your request because Assertion in "/Volumes/Development/vb_leopard_r2/AlturaPorts/NewFileLibs/CoreFoundation/MacBuild/../../Sys/Sys_FileLoc.cpp", line 199
When I try to import a snippet from snapper into the Session, PT crashes.
I already repaired permissions, disks, deleted Prefs and all Databases.
Any suggestions?
Thanks a lot!
Benjamin
Mac Book Pro, 2,4 GHz, 4GB RAM, OS X 10.5.8
PT LE 8.0.3, MBox 2
Old 09-25-2009, 02:19 PM
basslik's Avatar
basslik basslik is online now
Default Re: Assertion in ... line 199
Originally Posted by Simmer View Post
Hello there,
Any suggestions?
Thanks a lot!
Benjamin
Have you tried within PT from the import menu, importing the file so it can convert it in the session?
Old 09-25-2009, 02:39 PM
KingFish KingFish is offline
try running the Database Pref Helper tool from the troubleshooting Sticky, Repairing Permissions in OS X, and re-installing the Last CS Update for your version of Pro-Tools.
this combination of things has helped me through Assertion errors in the past.
David
- MacPro 6,1 Intel Xeon E5 2.7 GHz 12-Core 128 GB 1066 MHz DDR3
- HDX II Sonnet xMacPro Server
- 16x16 HD i/o x 6
- PT 2018.10
- OS X 10.14.4
- ProTools Dock / PT Control
Old 02-23-2012, 11:55 AM
ILOVEPROTOOLS ILOVEPROTOOLS is offline
this was just plaguing me for hours now. I reinstalled, repaired permissions, and deleted databases which didnt work, my final solution was to unclick spot as region in soundminer and to clear all unused regions and that FINALLY worked. That was an hour of my life wasted.
slashasteriskmusic
Old 02-23-2012, 12:55 PM
just happened again, selected all unused then removed them all and everything worked out.
slashasteriskmusic
Old 02-23-2012, 02:53 PM
ok one more thing to add... when I have the search function "by name" on looking in the bin thing is when I get the error, when i turn it off the error is gone.
slashasteriskmusic
Assertion in line 304 lobenmai Windows 0 12-24-2013 08:55 PM
Assertion line 330 steveskinner macOS 9 12-22-2012 10:34 PM
Assertion line 74 mikeeovitch macOS 0 10-08-2011 05:53 PM
Line 981 Assertion Jeffrey Talbot Pro Tools TDM Systems (Mac) 24 02-10-2011 07:20 PM
Assertion line 481 jrtme Pro Tools TDM Systems (Mac) 2 04-18-2010 10:19 AM
