Old 08-08-2007, 09:26 AM
JIT JIT is offline
Default Connect controller via USB or MIDI?
Do i need a MIDI cable to connect my Axiom to M-Box 2 or can i just use USB to my PC?
Old 08-08-2007, 09:50 AM
DigiTechSupt's Avatar
Default Re: Connect controller via USB or MIDI?
Using the USB cable is all you need.
Avid Audio Tech Support
Support FAQ
Old 08-08-2007, 03:22 PM
soundboy35 soundboy35 is offline
Which will perform better, USB or MIDI connection?
I wonder if that's part of my problem...
Mac Pro Dual 3GHz
10.8.5, PT10.3.9
MacBook Pro 15in, 2.3gHz,i7 Quad Core
10.12.6, PT12.8.
Old 08-08-2007, 03:53 PM
There should be no difference in performance. USB is possibly a bit more reliable, with less MIDI latency, but not a big deal either way.
Support FAQ
Old 08-10-2007, 12:33 PM
JIT JIT is offline
Thanks.
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input yellow Eleven Rack 1 05-04-2012 03:33 PM
Setting up a USB/Midi Controller while using a tascam audio/midi interface disabledpro001 macOS 5 03-30-2012 07:06 AM
Pro Tools Le 7.4 - How to connect USB controller Morgann7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-24-2010 06:02 AM
how to connect midi controller to project mix? GStyle Pro Tools M-Powered (Win) 1 03-21-2006 10:29 AM
Trying to connect my midi controller Bjarni 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-12-2005 12:52 AM
