Old 04-18-2007, 07:55 AM
innerbooty innerbooty is offline
Default Bounce To Disk inserts silence at start of bounce - PT 6.4.1
I've got a super annoying issue on my Mix system, Pro Tools 6.4.1, G4 / 933, OSX.3.9. When I do bounce to disk for regions where the audio is supposed to be continuous, starting immediately with audio, I find when I try to line all the bounced regions together that there is tiny amount of silence that gets inserted at the beginning of each bounced region of audio. I can't just delete the silence because there is actually supposed to be audio there. Is there any reason why this should occur? If I do a bounce to disk that starts at a certain location within a session, shouldn't the resulting bounced file begin exactly at the audio that occurs at that location?
I never had this problem in PT 5.1.1 on OS9, just in PT 6.4.1 in OSX. And I can't upgrade to a new version of PT because this is last version that supports Mix cards.
Thanks - Steve
Old 04-18-2007, 08:13 AM
tj_davies tj_davies is offline
Default Re: Bounce To Disk inserts silence at start of bounce - PT 6
Is your delay compensation turned on?
Try to RTD instead, that way you see the recorded file immediately.
Hope this helps,
Timothy
EDITED: Ups, sorry I think there is no automatic delay compensation in PT6, but there should be the TimeAdjuster-Plug In, which you can set according to the delayed samples.
G5 10.8.5
PT 10.3.9 HD2
www.pearls-music.com
Bounce to Disk issues and bounce to direct show error. SeattleHank Windows 7 01-01-2014 12:41 PM
Newbie to PT: Only Silence When I Bounce lenmorgan Pro Tools 9 25 02-03-2011 10:48 AM
Bounce to disk cant bounce with MP3 (PRO TOOLS m-powerd)) DCstudio10 Pro Tools M-Powered (Win) 2 09-04-2009 09:27 PM
Bounce to disk error - pro tools won't let me bounce the file! HipHopHead Pro Tools M-Powered (Win) 1 05-14-2009 11:13 AM
how do i tell 'bounce to disk' when to start and stop? heartparts 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 10-09-2002 07:14 PM
