Old 05-14-2005, 06:20 PM
benny_b benny_b is offline
Default power supply recommendations?
Hi All,
Sorry in advance - I'm sure this is a played-out topic.
I've been looking to replace the noisy power supply in my old beast. I know that the Enermax units are popular with the Allenstein crowd, but I'm concerned with compatibility: I'm running an old dual P3 700 Slot 1. I haven't built a system in a while and I'm wondering whether there are any potential problems with these modern power supplies when installed in machines from a generation or two ago. I'm using ATA drives, so PSUs with SATA connections need not apply.
I'm placing the importance on low noise. This machine is an old Dell Precision Workstation 210 and originally had a Dell (seems to have been made by Trend) 300 or 330 watt supply (NPS-300GB B). Appears to be ATX spec, but seems a bit bigger and heavier than most I've seen.
I'd like to keep it under $100 if at all possible.
Also, fanless models need not apply.
Thanks in advance; your advice is much appreciated.
Would this UPS (Uninterrupted Power Supply) protect and power my gear? D_Japan macOS 4 07-24-2011 04:23 PM
rackmount case / power supply recommendations? xodiac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-01-2008 08:57 PM
002 power supply/bad power harness? please help :( djkiller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-07-2005 08:04 PM
Phantom power and mic with power supply? hotstuff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-20-2005 12:56 PM
BAD POWER HARNESS/POWER SUPPLY!!??HELP!! snuffacation 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-11-2004 03:03 PM
