Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 01-25-2020, 07:50 PM
SomeOtherGuy SomeOtherGuy is offline
Default Question re MTRX digital insert point
I’m not having any success interfacing a Bricasti M7 digital reverb as a digital insert point in the MTRX. Previously I had it connected via an analog insert point with no problem
Right now it’s connected via AES in/out channels 7 & 8 on the MTRX, and I have *digital* and 48K set as the format in the Bricasti, same as the MTRX. I have that going to Digilink 15 & 16.
Maybe I don’t have it configured properly in the DADman software. Any tips appreciated.
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs
Old 01-26-2020, 07:23 AM
creativecontrol's Avatar
Default Re: Question re MTRX digital insert point
Greetings,
This should just be a matter of ensuring that you are patching the correct IO resources in and out of DigiLink - which connects Pro Tools.
In the DADman router:
Input: AES -> Output: DigiLink
Input: DigiLink -> Output: AES
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-26-2020, 03:04 PM
BScout BScout is offline
Is everything "green" in DADman? the return signal (though sample rate is set the same) may not be clocking on the Bricasti to the MTRX which it needs to be. If you open the configuration patching matrix in DADman, confirm that each channel has 48k and green for the connection. This has happened to me before where signal was not passing through though the overall patch between output to input was marked with a large green dot and everything being ok, the individual channel was actually not clocked. DAD helped me trace this problem by looking at the per channel readout showing both 48 and a green dot.
Also, assuming since this is an insert, you are using digilink 15/16 input and output (both) patched to your AES connections to the Bricasti (AES connector choice doesn't matter as Pro Tools doesn't see it.)
Old 01-27-2020, 11:38 AM
I think I have the routing correct. It could be clocking issue from the Bricasti (which has no word clock input). The Bricasti is connect to AES channels hardware 7 & 8, and assigned to channels 15 & 16 as insert point in Pro Tools.
File Type: jpg Screen Shot 2020-01-27 at 11.34.38 AM.jpg (45.1 KB, 0 views)
File Type: jpg Screen Shot 2020-01-27 at 11.34.53 AM.jpg (48.1 KB, 0 views)
Old 01-27-2020, 12:23 PM
Why are you trying to use this processor as an insert? For reverbs it makes more sense to create a send return routing in your Pro Tools template. If you were patching in an analog or digital dynamics processor you would certainly assign it to the Inserts tab of the IO Setup however.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-27-2020, 01:27 PM
The reverb is an insert on a reverb bus, with individual track channels feeding it via their sends. Set the reverb to 100% wet, and that's it. Just like any other plug-in reverb setup.
Old 01-27-2020, 01:28 PM
All those red triangles say your Bricasti clocking is off.
You need to get the Bricasti clocking right (needs to clock to incoming AES signal)
That is your problem.
(also agree with Jeff: reverbs on send/return setups; never inserts)
Old 01-27-2020, 01:31 PM
Okay but the Bricasti channels are green; other non-connected AES channels have the red triangles.
And it is in a send/receive setup, as per my previous post. Unless you both mean another way to set it up...
Old 01-27-2020, 04:01 PM
Contrary to your description of the assignments, your output routing (based on the screen grab) from Pro Tools to the Bricasti is not assigned to AES 7-8 but rather AES 15-16 which would hit the second DB25 breakout on the MTRX.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-27-2020, 04:37 PM
As I understand it, Pro Tools doesn’t see the physical AES input, but rather what the routing is for that input. Is that not true?
How to go from Apple TV digital out to MTRX? SomeOtherGuy Pro Tools | MTRX & MTRX Studio 55 02-08-2020 02:52 PM
How do Insert an in point and out point in my tracks and play this as a loop. scottee Windows 2 08-15-2012 08:08 AM
Playback starts wherever I make a selection or any insert point asuanlarm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 04-03-2009 01:24 PM
Not using the first insert point Paul Maunder Pro Tools TDM Systems (Mac) 1 04-06-2007 03:47 AM
DNS 2000 Best Insert point? Mubeau Post - Surround - Video 5 11-12-2005 04:26 PM
