Old 02-13-2019, 06:58 PM
oldmanpotter oldmanpotter is offline
Default unable to pan via chan. strip encoders
The encoders for panning parameters are not working on the channel strips. The panning acts as if one is holding down the OPTION key--the panning jumps to the default position as soon as you move the knob. The panning knobs on the master module work, as do the joysticks. Just not the encoders on any given channel strip. This is happening only on one of four connected PT rigs, so I'm guessing it might be a setting in Pro Tools?
thanks in advance,
oldmanpotter
It takes a big man to cry; it takes a bigger man to laugh at that man
Old 02-13-2019, 07:52 PM
creativecontrol's Avatar
Default Re: unable to pan via chan. strip encoders
Greetings,
If the value actually jumps from X to 0 then a default / null is being performed which indicates an OPTION key is being triggered somewhere from that particular workstation. I presume you have relaunched WS and PT on that rig? What version combination of WS, PT and OS are you running?
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-14-2019, 04:44 PM
Thanks Jeff,
Note that this behavior only happens with that particular encoder, not with the joysticks, or the master module encoders. Yes, I did restart the entire system. Here are the specs:
M40 frame
WS version 18.3.0.244
OSX 10.12.6
PT 2018 4.0
Old 02-14-2019, 06:02 PM
So - a single encoder on a Process Module or a Knob Module? Do the other encoders on that same module work fine?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-15-2019, 05:16 PM
Not sure about the other encoders on that module--I'll test later--but I know that the same encoder (bottom knob of the knob module) on other channel strips are behaving in the same manner.
Old 02-19-2019, 01:56 PM
Jeff,
Thanks for your advice but the problem has fixed itself--unable to get it to repeat.
Peter (oldmanpotter)
Old 02-20-2019, 05:27 AM
Glad that the issue has gone away. Please let us know if anything changes.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Chan. Select on mono strip activates Spill Steven1145 System 5 0 09-08-2017 01:58 AM
A Trick to jump to chan where a bus routes to ? LukeFromBerlin macOS 2 03-11-2012 12:39 PM
003 Factory + 8 Chan pre = 16 ins? -3db 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-05-2009 01:38 PM
Eq 31/ oct for moniotr chan.. kalunga VENUE Live Sound Systems 4 04-28-2009 09:32 AM
002r - 8 chan of D/A Produce_Dept 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-26-2005 09:07 PM
