Old 01-17-2010, 03:44 PM
bigstribs bigstribs is offline
Question H/W Buffer Size - reduce - increase?? cant win
In the middle of recording i get a error, Reduce H\W buffer size.. Ive reduced, then it says to increase, and so on... What is the best setting so i do not receive this error. I upgraded to what i thought was a fast PC to get rid of this error..This seems to be a common problem.. Any help?
The operating system held off interrupts for too long. It this occurs often, try increasing the
"H/W Buffer Size" in the
Playback Engine Dialog
(-9092)
I'm running
Windows 7
Pro tools 8.0.3
Mbox 2 Pro
8 Gig Ram
AMD Phenom(tm) II X4 810 Processor 2.60GHz
64 Bit OS
Old 01-17-2010, 05:42 PM
sw rec sw rec is offline
Default Re: H/W Buffer Size - reduce - increase?? cant win
"FAST PC" is a bit misleading, and we'll need a sandra report so we can see if your system is actually COMPATIBLE (By current standards, my system isn't FAST but it works because it IS compatible.)
Usually though, this set of errors results in attempting to record to your system drive when what you should be doing is recording to dedicated, separate audio hard drive.
AMD's are not as reliabale as INTEL processors for running Pro Tools. And do you have the 8.0.4 drivers in place for your 64-bit OS?
Old 01-17-2010, 07:36 PM
okay, i switched to record to another hard drive... so far so good.,,
how do i run a sandra report..
and where can i get the 8.0.4 driver updates..
Old 01-17-2010, 07:47 PM
TOM@METRO's Avatar
Here ya go.
http://duc.digidesign.com/showthread.php?t=193637
http://www.digidesign.com/index.cfm?langid=100&navid=54&itemid=40492
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 01-20-2010, 04:50 AM
systemexclusive systemexclusive is offline
(-9092)
I'm running
Windows 7
Pro tools 8.0.3
Mbox 2 Pro
8 Gig Ram
64 Bit OS
"Setup -> Playback Engine ->RTAS Engine"
If "Ignore Errors During Playback/Record" checked, try to uncheck "Minimize Additional I/O Latency".
Option "Minimize Additional I/O Latency" vary for certain system...
"Chapter 5: System Setup" page 45.
"Suppressing RTAS errors requires at least
128 samples of additional buffering on some
systems."
So, by activating "Minimize Additional I/O Latency" you cause buffer to be less, but CPU sparkle can trigger "H/W Buffer Size" ...
macpro 2.6ghz, 4gb ram, osx 10.6.1, macbookpro 2.5ghz, 4gb ram, osx 10.5.8
mbox2pro, mbox2micro, emu1616, protools8le, reaper, logic express, axiompro49, padkontrol, rode nt2-a, lexicon mx300, uad2laptop
r3, microQ, Albino3, impOSCar, Structure
m1active 520 & sub gw s750, deq230, cx2310
H/W buffer size cannot reduce any further Mike1360 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-17-2012 11:40 AM
6.8.1 increase/reduce h/w buffer size rudysg1234 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-10-2007 12:28 PM
increase or reduce h/w buffer size paquito 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 19 08-23-2007 01:48 AM
Increase & reduce H/W buffer size errors Nikki 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 03-25-2005 10:49 PM
Reduce/Increase HW/Buffer Size Problem :( Simon_Night 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-12-2004 04:29 AM
