#1771
Re: i7 Builds - Specs and Results
Awesome... think the performance increase over win XP can be attributed to the increase of ram available to pro tools? I can't wait to try oh ess X with 12 GB ram! |
#1772
This really puts @pple's $3299 8 core Nehalem 2.26 Xeons to shame. I still have no theory about why that is though
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9 |
#1773
Will you guys ever change the Dverb test to make 64 "the standard" test buffer setting??
I will search through this thread to see what you are getting at 64. I'm looking to build one and never want to change from 64 (recording and mixing), if possible. thanks. |
#1774
i leave my machine at 64 most all the time. with pt 8 and NO oc'ing i get around 242 dverbs.i get a good way through the mix here, but usually bump it up to 512 once i get towards the end of the mix
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#1775
Sweet. I usually get mix sessions from 30-50 tracks. I'll add auxes and use some as group busses, others for efx returns(reverbs and delays mostly). Eq and compression either on each track or group busses. other efx here and there. I never go overboard (on plugins per track). |
#1776
& here I am getting ticked off b/c my last mix I had to go up to 128 Hundred or so voices, many many auxes, many many plugs(2 TL SPACE, ! RVERB, ! T-Racks 3x w/Pultec & 670 on just to name a few) 19 instances of REASON Rewire, Mini Grand & Vienna Ensemble running as well(9 Midi tracks of that)...
#1777
#1778
edit: HERE is the session (video) I'm speaking of... Did this for Shane b/c we were discussing back & forth about midi on large sessions etc. it's sorta long & I didn't wanna post it on youtube so download @ ur leisure only if U'd like...& on here I U will see I have it going @ 64samples but the more time went on I had to bump it to 128
#1779
#1780
yeah it is... & I mean I was reallllly upset when I had to go to 128 b/c I've been set on 64 since I got it... Like I said, for whatever reason, Its giving me little pops here & there ever since I did a OS repair last week.. Before then, It hadn't come off 64 even with those type of sessions... But heyyy, I definitely couldn't have done that on my old Core2duo
Best Core 2 Series Desktops-Results and Specs | sunburst79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2416 | 02-19-2013 07:49 PM |
new to pc builds | chazc080488 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-18-2011 07:10 PM |
any p45 builds | fofif5792 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-09-2008 12:47 PM |
OSX "builds" | Richard Barrie | Pro Tools TDM Systems (Mac) | 2 | 10-18-2004 08:37 AM |
