Old 07-30-2010, 03:11 PM
Y.B. Y.B. is offline
Post mbox2 micro
I have a presonus adiobox interface. If I purchase a micro, will I also need an interface or can I run on my presonus?
Old 07-30-2010, 03:16 PM
Hotcrazyfruit Hotcrazyfruit is offline
Default Re: mbox2 micro
Please dont double post. an mbox micro is nothing more than a hardware dongle to allow you to mix on protools LE with portability. its only got 1 output, an 1/8 inch headphone jack. im not sure how you mean how u can run your presonus... it will nto work with PTLE if thats what your asking.
Core i7 920 OC'ed @ 4.0 GHz (200 X 20)
12 GB Patriot Viper Extreme
Asus P6T
OCZ Agility 64 GB SSD
Hitachi 1TB 32 MB HDD
WD Caviar Black 500GB
Saphhire HD 5850
3 x 20" monitors
Eleven Rack w/ ERXP
Fender Super Champ XD
Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet
Old 07-30-2010, 03:28 PM
So "not work with PTLE" means I cant record thru another interface? Just mix?
Im trying to find a way around using a (what I think) lesser quality interface.
Old 07-30-2010, 05:03 PM
Dism Dism is offline
Get an MBox Mini.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 10-10-2010, 04:23 PM
IVIrStubbs IVIrStubbs is offline
Y.B.,
The MBox Micro will allow you to do two things. One is that it will allow you to open the ProTools software. There are no inputs on the micro as you know, so you won't be able to record audio with it. And just because you have ProTools open with the Mbox Micro, that doesnt mean ProTools will then recognize a non avid/digidesign interface for recording. The only recording you will be able to do into ProTools while using the micro would be midi data for virtual instruments/etc. via something like the M-Audio "Uno", which is what i'm currently using, or some other suitable/qualifying midi interface to fit your midi needs. Otherwise, an interface HAS to be from Digidesign/Avid with audio inputs for u to be able to record audio into ProTools, regardless of which version of the software the interface was designed to work with. Hope the info helps
Mbox2 Pro & Mbox2 Micro on the same system Freakazoid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-16-2011 01:38 AM
mbox2 micro Y.B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-30-2010 05:00 PM
Old MBOX2 Micro sureno 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-23-2008 01:14 PM
MBox2 Micro feryano 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-17-2008 04:04 PM
MBox2 Micro on PT LE 6.9.2 Keepsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-01-2008 11:46 PM
