Old 06-06-2018, 10:44 PM
Simon Reich's Avatar
Simon Reich Simon Reich is offline
Default Midi echo or duplicate notes HELP
I have searched through the forums trying to find out why I am getting two notes for everyone one I input through my midi controller keyboard. I have worked out how to get rid of them (event-remove duplicate notes), but it is really annoying as an event after the fact.. The threads about this show someone has accidentally put a midi cord in and then out again, causing the midi echo. This is not the case here. In fact, this anomaly only just happened recently. I've had the same setup & same controller keyboard (Roland RD-700GX). I've explored all midi options on the out of my keyboard and all options on the midi input (M-Box). Please help, as this is wasting so much time each session?
Simon Reich
Model : ASUS All Series ASUS MB Mainboard
ASUS Z97-A
BIOS : AMI (OEM) 0902 05/08/2014
Intel vPro : 9.01.01.1000
Total Memory : 16GB DIMM DDR3
Processor : Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz (4C 3.9GHz, 3.9GHz IMC, 4x 256kB L2, 6MB L3)
Operating System
Windows System : Microsoft Windows 7 Personal 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Old 06-06-2018, 11:46 PM
Stig Eliassen's Avatar
Default Re: Midi echo or duplicate notes HELP
Welcome to the community.
USB or MIDI connection? Both?
Have you possibly enabled another overlapping zone on the keyboard, thus sending two notes for each key press?
Have you tried a factory reset on the keyboard?
Old 06-07-2018, 06:21 AM
elicious elicious is offline
If in your MIDI input select field, you have it set to All,
go into your midi studio set up and assign your specific keyboard,
then in MIDI input select on your track,
select the instrument you created
and a specific channel and you should be good.
e
ihatetyping
Old 06-07-2018, 08:37 AM
I had this happen when I was using a Roland TD-10 kit. Turned out that having MIDI cables connected both ways(so MIDI came back while recording) was the cause(unplugging the returning MIDI cable solved that one)
Old 06-08-2018, 04:10 AM
On my Yamaha Motif 7 I have both the MIDI out and input connectors connected to my Motu MIDI Timepiece AVUSB. What I did/do is to turn off local on in the Yamaha's setup.
Jack
QAPLA!
Old 06-08-2018, 04:13 PM
Oddly enough, my Motif es8 has no problem on this
Old 06-08-2018, 09:34 PM
I am using a midi cord (5 pin) & no USB. In the original question I posted, I noticed that other posts addressed that issue, but I have never had a cord double back situation, which would obviously cause a midi echo. I have also assigned the actual keyboard I use & have no overlapping zones. As I said in the question, I have been using this setup for about 7 years with no problem. The only recent change has been moving my studio to another room. I just don't know what is causing this, as I have not changed any settings on the keyboard or Pro Tools 11. HELP????
Simon Reich
ASUS Z97-A
Operating System
Old 06-09-2018, 03:35 AM
Simon:
Get the utility program called MIDIOX and run it. It should tell you what MIDI messages are going back and forth from your keyboard. Also try resetting your keyboard to factory settings. Obviously something changed in moving and it's not in PT11.
Jack
QAPLA!
Old 06-09-2018, 07:47 PM
Thanks for that tip. I'll check it out & let you know the outcome. Is the program to detect midi traffic free?
Simon Reich
ASUS Z97-A
Operating System
Old 06-09-2018, 11:04 PM
Simon Reich
ASUS Z97-A
Operating System
Duplicate MIDI notes? Monaco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-08-2013 01:29 PM
MIDI Editing duplicate notes AMcG Pro Tools 9 1 10-26-2011 07:28 AM
Duplicate MIDI notes with AXIOM 61 problems proverb18 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-07-2007 02:43 PM
MIDI ghost/duplicate notes problem...HELP! vocalvoodoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-02-2005 08:12 AM
How do I remove duplicate MIDI notes? Rob Ruce 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-11-2003 02:51 PM
