Dolby Atmos Production Suite trial
Is the trial version of the Dolby Atmos Production Suite found here:
https://developer.dolby.com/forms/do...n-suite-trial/ The same as the one sold by Avid? That site says it's a 90 day trial, is that correct?. And is the trial limited in anyway?
Justice C. Bigler www.justicebigler.com Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools Ultimate 2023.6 / HD|Native-TB 2018 MacBook Pro: six-core i9, 32GB, 1TB, Monterey / Protools Studio 2023.6, / DVS / DAR, L-ISA Studio Home/mobile: Focusrite Red 8Pre+HD32R / Clarett 4Pre Road/hotel: Roland OctaCaputre / Apogee One |
Re: Dolby Atmos Production Suite trial
Yep, that's the same as the one sold in the Avid store. IIRC, there were no limitations during the demo. Check it out! But give yourself time if you're new to the workflow. There's a lot to learn.
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn |
Great, so the trial doesn't do anything stupid like blasting white noise every 30 seconds? Or limiting how long each project can be?
Is it worth checking out even if you don't have all the surround speakers and can only use the binaural headphone rendering? (FWIW, I'm quite familiar with mixing live shows in immersive environments and using object based maxing having toured with L-ISA and used SpaceMap).
Inside DAPS, you can turn loudspeaker processing off, which will reduce CPU usage and also make the metering and monitoring more straight-forward when using headphones for binaural rendering alone. I recommend using the Dolby Audio Bridge, LTC (not MTC) timecode, and using an aggregate output device from DAPS (more info on that topic in the manual). Many preferences that are very important in binaural including near/mid/far object distances. Personally, I prefer the 7.1.4 loudspeaker experience, but the binaural experience is really good.
Sweet, thanks for the info. I have a symphony mix that I need to finish. But then I have a couple other projects in May that I want to try out with Atmos and then spend some time over the summer working with. I'm pretty sure that I'll just go ahead and buy it, but wanted to make sure that it would function and work the way I think it should first.
Will it run on a MacBook Pro?
DAPS - single CPU system for making home theater and music mixes DAMS - multi-CPU system for more elaborate home theater mixes with the renderer (DAMS) on a dedicated Mac or Windows machine DA Cinema - high-end, lease-only multi-CPU system and Windows renderer for mixing films in Atmos. Not to be discouraging, but I don't recommend releasing anything that you haven't had the chance to hear in 7.1.4. Before I upgraded my studio to 7.1.4, I worked on music mixes with DAPS and then took them to a better-equipped room to finish them. Last November, I connected TIDAL to my rig. AMAZING. There are some great Atmos albums out there.
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn Last edited by reichman; 04-12-2021 at 06:12 AM. |
Also, what kind of speakers are you using for your system? I'm currently using a pair of Genelec 1031As. But I want to trade them out for a pair of Neumann KH120s. But for 11 speakers my budget would be more in line with some Presonus E5s.
Are you using a receiver? Can you detail a bit on how you´re monitoring Tidal from your computer DAW on your setup? Thanks
Regards, Paulo M MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura Protools Studio 2024.3 |
Anyone with any insight whether DAPS will be PC compatible at some point? I have a HP z840 workstation and was curious on how to implement DAPS in my computer without needing another dedicated computer.
FS: Dolby Atmos Production Suite License | LDS | Buy & Sell | 1 | 10-20-2020 02:37 PM |
Dolby Atmos Production Suite on Westmere 5,1 | Stevo499 | Post - Surround - Video | 1 | 06-05-2020 07:36 AM |
Dolby Atmos Production Suite 3.02 download | LDS | Post - Surround - Video | 3 | 08-20-2019 07:03 AM |
Dolby Atmos Production Suite | garnoil | Post - Surround - Video | 2 | 03-13-2019 08:34 AM |
Dolby Atmos Production Suite | subhuffer | Post - Surround - Video | 20 | 03-10-2019 06:40 AM |
