Latency when tracking into Pro tools
I set up my Pro tools to act as the master and my external sequencer as the slave for recording using MTC. The only problem is when it begins recording, there is a slight delay, and this delay snips off a small piece of the beginning of my tracks. Can anyone offer some insight on correcting this?
Thanks! |
Re: Latency when tracking into Pro tools
If you haven't already, try clicking the Midi symbol in the transport window of Pro Tools (next to the metronome symbol). This tells Pro Tools to wait for incoming (Midi) data before "recording".
take frank's advice. and also make sure your system is setup for the least amount of latency. i.e., 128 samples for the buffer, and make sure low latency monitoring is checked.
Jeremy Forbis |
Thanks a lot friends for your inputs. I tried both to no avail. The problem is that it's not taking my absolute whole song (from my MPC 2000xl) from time zero. It's chopping like a second off. I think the problem might be the amount of time that the pro tools needs to sync up with the MPC, I'm just not sure how to remedy that. Anyone else have any suggestions?
Thanks a lot for your help! |
When I've been working in reason and cubase (similar thing except all software based) I'll add a measure or two to be beginning of the sequenced tracks to let the other software get stabilized.
That might be your easiest solution. |
Thanks Gary O...I actually tried that already and it worked because I got my whole song in there from time zero but I had that blank there in beginning. Track for track, do all them sync with the exact same latency? I guess I can just snip off the blank bars off of all my tracks provided that they all have the absolute exact same amount of latency...that's another issue.
your welcome for the suggestion.
I can't answer on the latency issues though since I'm not experienced with protools. I would assume they would track with similar latency, since subsequent tracks are synced off the same time code... But again, no experience here, just throwing out some ideas. [img]images/icons/smile.gif[/img] |
Tracking latency 001 vs. 002, 003? | marchhare | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-22-2007 12:05 PM |
Is tracking latency getting better on LE/MP? | autodidactic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-26-2007 07:11 AM |
low latency tracking with reverb | stevejones | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 09-06-2005 06:48 PM |
Tracking Latency | philrecords | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-24-2004 11:18 PM |
Tracking Latency | seawell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-10-2004 09:32 AM |
