  #21
Old 10-18-2018, 05:58 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Mbox3 Pro: +4 Line Input Unity Gain
Originally Posted by Roivas View Post
I just need to know what unity gain is as far as setting the knob in front.
I assume that if it's all the way down counter-clockwise, no gain is being added and this is pretty much unity gain (as close to bypassed as you can get).
That’s not unity, that’s the opposite of unity. Sorry if this has been addressed already in the thread I didn’t read all of it.
If you think of a mixer unity is at zero, Infinity is with the fader all the way down
What did the mbox Manuel say?
If you read into this a little more, it’s might be fairly obvious that I would prefer the information come from Avid than from me as far as my employer goes. Make sense?
Good luck with that, tell your employer to give avid 40 bucks ffor (I’ve got a stuttering problem don’t laugh) a service call and then they’ll answer any question you have, officially speaking
Daniel
  #22
Old 10-18-2018, 08:24 PM
Roivas Roivas is offline
Default Re: Mbox3 Pro: +4 Line Input Unity Gain
Well, mic input gain can be at unity all the way down (counter clockwise) on a mixer. On the MBox, the only way to reduce the line input gain below unity seems to be to pull the knob and engage the -20dB pad. I really don't know yet.
Anyway, there are quite a few booths at this freelance gig. They might not all have MBox Pros. Some of them might be regular MBox's (which all kind of look the same as far as I'm concerned). This would explain the line input gain issue when I find knob set at 12 o'clock.
I'm no expert on these devices and I don't think I've had to use one in the last 10 years.
About your other comment regarding the $40, I don't know about that one, ha ha! Good idea, but my spidey sense thinks not.
  #23
Old 10-18-2018, 09:54 PM
YYR123's Avatar
By reading the manual it appears that unity gain (0+/- added gain) is 12 o’clock on the dial.
While it doesn’t expressly say it, it is conferred in context. The manual actually says the phrase at least 3 different times.
It reminds me how easy it was to read the manual and understand the hardware. Avid always did a good job of that IHMO
File Type: jpg 7254E568-603D-4BB6-9D26-25374D96D01B.jpg (37.1 KB, 0 views)
Daniel
  #24
Old 10-18-2018, 10:24 PM
If it were an output knob, I'd be more inclined to accept that. The manual doesn't make this clear enough for me to use as a source in this circumstance. Don't want to just guess at what it might be.
  #25
Old 10-19-2018, 08:58 AM
YYR123's Avatar
Good luck then
Daniel
HD Omni line input gain adjustment bissodj Pro Tools HDX & HD Native Systems (Win) 4 02-02-2014 02:00 AM
protools 10 clip gain line /volume line alidav Pro Tools 10 3 03-09-2013 05:21 PM
Mbox 2 Line (TRS) Input Gain Control taylor4814 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-29-2011 09:24 AM
MBox 3 Pro Line Input (rear) Gain Garry R 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-23-2011 03:28 PM
002R Unity gain on line inputs .... john1192 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-15-2007 05:33 PM
