Old 09-05-2018, 11:09 PM
mattrixx mattrixx is offline
Default Dock 12 Softkeys going to sleep
Hi Folks,
This one goes out to Eddie.
I know this was supposedly addressed in an early update a while back (I'm not sure what the thread was called either), but I am having the issue where after a while, the Docks soft key buttons become inactive.
They still display the correct colours etc, but I have to toggle between Soft keys and Transport using the bottom left button to make them spring to life again. Otherwise they don't do anything.
It's been like this for a long time, but I keep forgetting to report it.
Does this happen to anyone else out there?
Regards,
Matt
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 09-06-2018, 12:22 AM
BScout BScout is offline
Default Re: Dock 12 Softkeys going to sleep
Doesn't happen here. System is left on continuously working or about 18 hours a day. The Dock is almost never rebooted.
What version of Eucontrol are you on and what is your Dock firmware?
Old 09-06-2018, 12:26 AM
Yes same here. All on 24/7
Latest version at this time. 18.3.0.244 Mmm
Matt McKenzie-Smith
mattrixx.net
Old 09-06-2018, 12:56 AM
And Dock firmware? There was a firmware update for the Dock not too long ago.
Old 09-06-2018, 01:07 AM
Yup.. apparently up to date.. 1.1.20.0
Matt McKenzie-Smith
mattrixx.net
Old 09-06-2018, 10:04 AM
EddieJones's Avatar
Yes this fix seemed to resolve most peoples issues. Have you customized the softkeys, I wonder if something in them is causing this. If so, could you try the default for a few days and see if that fixes it ? Another thing to try is a clean uninstall, using the 18.3 installer uninstall everything and check the uninstall prefs too, then reinstall.
Old 09-06-2018, 04:54 PM
Hi Eddie,
Thanks for getting back.
No I haven't customised the Soft Keys. The only customisation i have done, is on one of the User pages on the iPad. (Added some workflow macros).
Note, that the same thing is happening when I use its with Logic ProX too.
Will try an uninstall to see how that goes.
Matt McKenzie-Smith
mattrixx.net
S6 Softkeys PatrickCusack Avid S4/S6 4 05-23-2018 04:32 AM
Pro Tools Dock goes to sleep and wont wake up FLi Avid S1, S3, Dock and Control App 1 05-01-2018 05:40 PM
16 Softkeys not active Moviesound Avid S1, S3, Dock and Control App 54 10-23-2017 02:56 PM
Suggestion: Users of S3&Dock together: dock fader becomes 5th VCA master fader bassmagnetic Avid S1, S3, Dock and Control App 0 10-01-2016 08:20 AM
SoftKeys customizing - XML OvD Avid S1, S3, Dock and Control App 2 08-17-2016 02:32 AM
