Old 01-26-2020, 06:18 AM
XJENSEN XJENSEN is offline
Default EUCON Faders Off also sets Control app faders to -Inf?
Is it normal that when you send the EUCON Faders Off command, also all of the 'soft' faders on the Controller App are set to -Inf?
I understand all physical faders being set to -Inf, but I would expect the Control app to just keep showing the actual Pro Tools fader positions?
Old 01-26-2020, 02:55 PM
BScout BScout is offline
Default Re: EUCON Faders Off also sets Control app faders to -Inf?
Yes. Normal.
They need to Euconize "Suspend All Faders" found in Eucontrol>General Preferences. That would do what most of us would prefer over "Faders Off"
If you don't mind checking/unchecking that Eucontrol box, you'll get what you want.
UPDATE: They did Euconize "Suspend All Faders". It is found under Surface>Options>General>Suspend All Faders. So you can put it on a soft key on the Control app.
And it works brilliantly. All the hardware faders (dock, artist, etc) stop in place (they do not go to -inf) when you engage it but the Control app faders on the Mixer tab (etc) continue to move the way you'd expect them to.
Last edited by BScout; 01-27-2020 at 12:41 AM. Reason: Found they had added the command.
EUCON Faders Off Command... HFX Avid S1, S3, Dock and Control App 2 09-04-2019 08:41 AM
Faders off Eucon command not working Led Artist Series 4 07-24-2016 05:39 PM
Avid/Digidesign Pro Control 16 Faders (Main Unit + 8 faders pack) Eduardo Apolonia Buy & Sell 3 11-24-2015 09:56 PM
Custom Faders moves position of all other faders!?! freeBase ICON & C|24 5 02-26-2009 06:44 PM
USING MIDI FADERS TO CONTROL PRO TOOLS FADERS.... domsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-08-2004 07:06 PM
