Old 07-11-2017, 01:58 PM
john1192 john1192 is offline
Default Re: Apple ProRes 422 and 12.8HD
Originally Posted by michael c View Post
Thanks John! I figured out a work around, but outside PT. Still a head scratcher. I would DropBox you a clip but not allowed to at this time per IMAX agreement.
no worries - totally understood !! may i ask what your workaround is ??? for our edification !!!
cheers john
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 07-11-2017, 06:56 PM
michael c michael c is offline
I just used QT Pro and added the stereo track since it was exactly the same frame rate / length as the 1920x1080. This is really just for the post production's reel for later use after the IMAX work airs.
Mac Pro 3.5GHz 6-core (6.1 2015)
Monterey 12.6.8
64 GB RAM
1 TB PCIe flash storage
Pro Tools Ultimate HD 2023.6
HD Native Thunderbolt
Old 07-11-2017, 07:05 PM
i was going to mention this scenario as i use it all the time to deliver different versions .. client can just turn on the version they wish to use .. the reason i did not mention is that your video was Black - so i assumed (bad thing to do) that your video wpould not be good enough to add the track directly to the QT ..
nice work .. !!!
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 07-12-2017, 10:43 AM
Cryos's Avatar
Cryos Cryos is offline
As far as I'm aware you need the ProRes Codec from apple. I remember having this issue and realized I didn't have the codec installed. I don't know if this is still the csae with 12.7 and above.
Cory Rizos, CAS
Re-recording Mixer/Sound Designer
Montreal, Quebec
http://www.imdb.com/name/nm0007185/
coryrizos.com
Old 07-16-2017, 11:58 PM
Bokir Bokir is offline
The other clip of the same material is a .mov ProRes 422 at 1920*804 and that is the one that shows up as 'blank'.
Exactly the same thing here ...
Satrio Budiono
FourMix JFS
Mac Studio Max M2 (2023), 32GB RAM, Ventura 13.6.4, PT Ultimate 2023.12.1, Sonnet TB2 III-D, Avid HDX 2, Sync X, MTRX Studio, Trinnov D-Mon, JBL 708P, 705P & JBL 3635 (Atmos HE 7.1.4)
  #16
Old 07-17-2017, 09:02 AM
I was never able to figure out why......
Monterey 12.6.8
64 GB RAM
  #17
Old 08-12-2017, 08:57 AM
JKHansen's Avatar
JKHansen JKHansen is offline
I'm having the same issue. Proves 422 Proxy alway worked great prior to 12.8 (and indeed was my preferred delivery codec) but working in a new project post updating to 12.8 the video is black and no frames display as originally stated in this thread. Yet this same file plays fine in finder and quicktime player.
I've also tried to convert a separately delivered AVC .mp4 version to Prores 422 (trying Full, LT and Proxy) using MPEG Streamclip and have the same issues on import. Indeed I can tell the video won't display before even importing as the preview pane in the PT video import window displays no video. I have all the proper codecs installed.
Is this a new bug in 12.8?
MacBook Pro (15" - 2018), 2.9GHz i9, 32GB RAM
OS X 13.6.3
Pro Tools Ultimate 2023.12
  #18
Old 08-12-2017, 11:48 AM
hi, have you tried converting in Compressor or just using QT ???? just thinking out loud !!!
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
  #19
Old 07-10-2019, 03:59 AM
priorytools priorytools is offline
Originally Posted by john1192 View Post
yes ProRes 422 works just fine .. what video codec are you used to working with in pro tools ??
cheers john
Hi John.
I'm having an issue with 12.8.3 after updating from 12.6.2 seeing a Prores 422 HQ file.
On the video track in the clip it says "media off line". .
I imported the file again to see if that would work, same result ?
An ideas ?
Josh
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
ProRes 422 cant be imported critictalk Getting Started 5 05-08-2017 12:09 PM
PT11.3.1 Not Playing ProRes LT remotedude Post - Surround - Video 5 05-22-2015 12:16 PM
read Apple ProRes 422 with PT 9 cozy_man Post - Surround - Video 10 02-02-2011 03:19 PM
Prores 442 Newpostguy Post - Surround - Video 11 04-10-2010 04:04 PM
Apple ProRes codec will play out firewire, why not so in PT? soundworx Post - Surround - Video 3 05-10-2008 08:55 AM
