Noobie question.
I'm not familiar at all with working in a DAW that has a limitation (outside of cpu power) on tracks. Pro Tools Le is limited to 32 mono tracks, 16 stereo, or a combination of the two. My question is this, do busses count against that total?
Re: Noobie question.
Bus count is completely separate from tracks. A bus in Pro Tools is just the route audio takes to a destination. Busses in Pro Tools can be routed to Audio, AUX or instrument tracks, so to answer your question: It depends on what you are sending the bus to. If you are sending from 6 audio tracks across a bus to an aux track (to re-create the "bus" of a hardware mixer), your audio track count does not increase against the limitation, no. If it is routed to an audio track, then yes, of course.
Ok, so basically, aux tracks do not count against the limitation? I get it.
The limitations of Pro Tools LE are as follows (covered on page 30 of the 7.4 Pro Tools Reference Guide):
noobie question | Hamsterlott | Tips & Tricks | 4 | 12-27-2009 04:42 AM |
Noobie bus question | hkenyon8891 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-02-2009 08:18 PM |
Noobie question. | kb420 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-27-2008 08:30 AM |
hi all noobie here and i have a question | cookiehead | Pro Tools M-Powered (Mac) | 4 | 12-04-2006 09:55 PM |
noobie Battery2/Kontakt routing question | skeeter | Tips & Tricks | 0 | 08-14-2006 08:20 PM |
