Old 09-17-2019, 12:40 PM
HenrikUdd HenrikUdd is offline
Default Anyway to get access to the native pro tools when being HDX ultimate user. Need HELP
Hey guys!
Ran into some problems today.
I’m gonna continue/finish a mix that was initially done on a non hd system with pro tools 2019.6.
Mixing guy wasn’t aware of the lack of side chain delay compensation and has used some stuff like that and pretty advanced routing but the mix sounds good on his system.
When opening the same session on my setup (HDX ultimate 2019.6) it’s sounds pretty horrible and thin. Room mics getting cancelled out and missing the oumphf from below. It’s like my system delays everything right and unforunately completely changes the mix.
Is there any way to get access to the native version so I can finish the mix the way it should sound? I’m on Mac latest before warning of updating. (Plugins are the same, tried online/offline record it etc etc.
Thanks for any help!
Old 09-17-2019, 01:06 PM
Default Re: Anyway to get access to the native pro tools when being HDX ultimate user. Need
AFAIK you need to lose the HDX card. Have you tried just using Built in Output as the playback engine? Hopefully you have monitors already setup or that can be switched to handle that.
Old 09-17-2019, 01:33 PM
Hey man!
I tried that earlier today and the first test bounce I did after switching to built in output nulled out (except some extremely low noise that got audible when clippgaining the nulled file +36dB, probably from softtube tape or something he’d used on the kick and toms) but after that first bounce I wasn’t able to reproduce it. Didn’t change a single thing in the session. Every other bounce I tried plays like 1.4db rms lower and is very noticeable different.
Loosing my mind a bit over this
Old 09-17-2019, 02:28 PM
daeron80 daeron80 is offline
Is it known exactly how many samples you need to compensate for on any given bus? If so, you could insert Time Adjuster on masters of each relevant bus.
David J. Finnamore
Old 09-17-2019, 03:57 PM
Farhoof's Avatar
Farhoof Farhoof is offline
Sidechain delay compensation can be turned on/off in the preferences on HDX.
There can still be a compensation difference though when using native plugins on auxes.
Old 09-17-2019, 11:23 PM
“Sidechain delay compensation can be turned on/off in the preferences on HDX.
There can still be a compensation difference though when using native plugins on auxes.”
Great! I will try this today. All plugins in the session is native except UAD ones.
Old 09-18-2019, 05:23 AM
Can't get it to match no matter what I do so I'll sort out a stereo drum export from the other guy, but it's really annoying that it's a difference between the HDX and native
Thanks for the replies
HD native card and Pro Tools Ultimate samplaire Pro Tools HDX & HD Native Systems (Mac) 2 07-05-2018 04:46 AM
FS: McDSP Analog Channel Native V5, 6020 Ultimate EQ Native V5 soundroad Buy & Sell 31 03-21-2016 06:03 AM
Admin Access vs. Restricted user access emf1138 Pro Tools 12 0 03-09-2016 09:42 AM
Access Violation 0x00000000 when loading Pro Tools 10.3.9 HD | Native amdini Windows 4 07-09-2014 11:12 AM
Native Instruments synths, how do i access them in pro-tools nuemethod Pro Tools M-Powered (Win) 2 04-01-2007 10:44 AM
