Old 03-07-2003, 05:54 AM
blankpro blankpro is offline
Default Using Mezzo to archive and restore
I am using Mezzo to archive to AIT tape.
My question is for those who are archiving projects, and then restoring them later, adding changes, and so on.
If I archive by dragging the project over, that's great. owevber, in my woirk i create multiple projects of the same audio files - various mixes, versions, etc. How does this work? Does Mezzo make multiple backups of my audiofiles? Or does it
'look up' the files in the project that is created?
The reason for this is obvious - I can't afford multigigs of projects for each song I make.
How do you do it?
Does the original project become the basis for all others? Do you need to drag each ptools project over each time into the folder?
Thanx in advance for the insight....
Old 03-07-2003, 08:15 AM
gandalf07 gandalf07 is offline
Default Re: Using Mezzo to archive and restore
Mezzo is supposly Session Wise but....
It works best when you drag the complete folder of your session, it will then see the session files and scan them, but the Audio Files will be backed-up only once.
Anyway, version 3.8 works better than the 4.x
SA Amin
THC Sound & Music
Old 03-07-2003, 08:18 AM
B. Summerfield B. Summerfield is offline
Mezzo will only back up audio files one time for multipule sessions, you do have to drag and drop the new versions of your session to the project window. If you move that session to another drive mexxo will consider it a new session and do a complete backup of all the files again.
Old 03-07-2003, 11:38 AM
ok, I understand that.
What I'm trying to do is have folders in mezzo for each song. in each folder will be multiple Protools sessions. When I drag a new verison of my mix to Mezzo, it makes that ptools icon into another project.
The problem is that I want to be able to see justa list of the projects in mezzo - I archive them and number tham so I would rather see
001
002
003
rather than
001
multi
voc
test
002
split
remix
etc
etc....
Mezzo Restore - from Exabyte ?? jeremiahmoore Digidesign Hardware & Software 3 09-04-2017 09:38 AM
Help with MEZZO restore chuckbutler Pro Tools TDM Systems (Mac) 62 02-02-2014 11:26 PM
Mezzo Restore - from Exabyte alex weber Post - Surround - Video 3 06-07-2011 09:45 PM
Mezzo Restore - from Exabyte jeremiahmoore Post - Surround - Video 3 08-27-2010 12:12 PM
Audio File Droputs after Mezzo restore John Mad Anthony Pro Tools TDM Systems (Mac) 1 07-28-2006 12:10 PM
