Old 03-03-2010, 03:57 PM
lennieh lennieh is offline
Default Dragging MIDI from Superior Drummer crashes PT
Protools V8.0.3cs1 in Windows Xp and Win7/64 I get the same behaviour in both...
When I drag a MIDI file from the Grooves window in Superior Drummer (V2.2.1) into my Protools session, 9 times out of 10 it causes an Access Violation in DFW.dll as soon as the mouse cursor leaves the Superior window. Same happens with EZPlayer Pro.
Anyone else seen this?
Anyone got any othe software that has draggable midi files?
Old 06-26-2011, 10:02 AM
bmenchen bmenchen is offline
Default Re: Dragging MIDI from Superior Drummer crashes PT
yes i have this issue in pro tools 9.03
havnt found a fix
Old 06-26-2011, 07:24 PM
luken26 luken26 is offline
Try updating Superior Drummer to version 2.2.3. That is the most recent update.
Hopefully that will fix your crash/access problems.
I am able to drag MIDI from the Grooves window in Superior Ver. 2.2.3 into PT 9.0.3 without any crashes or access violations.
Mac Pro (2019) with 3.5GHz 8-core Intel Xeon W Processor, 48 GB DDR4 Memory, 1TB SSD
Catalina 10.15.7
Avid Pro Tools Carbon, Eleven Rack (ERXP 2.0.1), Neve Shelford Channel, SSL Fusion Analog processor, Avid S1 Control Surface, Yamaha Montage 7 (also used as a MIDI controller), Korg Prologue 16 and Adam A7X Monitors.
Pro Tools Ultimate 2021.6, Logic Pro, VEP 7, Exponential Audio. Eventide, FabFilter. iZotope, McDSP, MDW, Softube, Sonnox, Soundtoys, Waves.
Old 01-03-2012, 09:54 AM
even with version 2.2.3. i get the crashes with protools 9
Old 01-03-2012, 01:08 PM
Stig Eliassen's Avatar
What about 2.3.0?
Superior Drummer 2 and PT 10/11 crashes jryser Pro Tools 11 9 07-28-2013 06:16 PM
Problem dragging MIDI grooves from Superior Drummer Webb macOS 0 11-11-2011 12:09 PM
Memory probs (crashes) with Superior Drummer 2.0 anybody else? RiF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 02-21-2010 10:54 AM
EZ Drummer? PT Error dragging midi files TDub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-28-2008 11:16 AM
