Bounced files sound dulled. MAJOR PROBLEM
For my last couple of projects I've noticed that my bounced files sound dull. To much bass, and way to little high frequencies.
My normal workflow is to send everything to a master channel. This Aux ouput everything to a Volume bus for surround calibration for my studio and such. It also output it to a Bounce track. The good thing with that is that I can very easily stop my bounce, do some editing and continue with the bounce, instead of using the bounce menu in the file menu. I'm sure alot of people do the same. So.Problem. WAAAY to much bass. WAAY to little in the high end. I also tried the bounce menu by the way. So. I did a little test. I put a EQIII on the bouncetrack. Cut of everything below 100Hz, and pulled up everything above 6kHz up by as much as 8dB. Now it kinda resembles what i allready got. Still a little dull, but better. So I thought that maybe my listening devices were off. But no. If I drag a bounce without the bounce EQ it sounds dull, if I drag a file with the bounce EQ it kinda seems right.. SO, WTF? Anyone had this problem before? I don't know what to do, since I clearly can't trust my rig.
"Don't trust the boomer" |
Re: Bounced files sound dulled. MAJOR PROBLEM
Obviously this is not normal and something must be set up wrong. Can you post the session file for us to check out?
Well, if my 12 years, and still going strong, of working as a sounddesigner hasn't made me a fool, I would know what the hell is going on.. It is pretty strange though --Especially since it clearly sounds different when I'm exporting it back into PT..
Link to sessionfile: https://www.adrive.com/public/KKMM4x...a_03_toDUC.ptx
Is this only on PT11? Is this an offline bounce? Or is it on PT10?
When did this start?
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
It's PT10.3-10.3.7
And it's both BTD and RTD. Same problem.. It started pretty suddenly maybe 4-5 months ago, when one of the distributors of a series called me up and said he thought it sounded a bit dull. And I have not changed my rig before that. I have however after that reinstalled OSX, PT. But the problem persists.
Got the session. Let me run some tests ASAP. Probably in the AM.
When you were EQing the bounce to match what you heard when you were mixing, I'm assuming you changed the output to the output named 5.1, is this correct?
I took your session and replaced the missing audio with some dialog I had here and it worked fined. No difference between the bounce and live audio.
What about trying to use the test signal generator? Record a track with a 15k signal and bounce it.Import it back to the session and see if it matches. You could do a null test to see if it is exactly the same. I bet it will be.
What is your bounce source?
Use pink noise as source and an rta that you will feed from different points in the signal chain. That will give you a way to qc/reference your chain.
Can you please send yourself over fiber to go spam some other forum? Darryl Ramm |
Pop at the end of bounced files | brickroadstudio | Pro Tools HDX & HD Native Systems (Mac) | 11 | 07-25-2011 06:42 PM |
Problem: bounced files have gaps at the beginning | Rowcliffe Browne | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-11-2005 10:08 PM |
Bounced files end gets cut off | breakie | Pro Tools TDM Systems (Mac) | 8 | 05-25-2005 01:26 PM |
Bounced files | shameeta | General Discussion | 4 | 11-09-2003 07:36 PM |
bounced files have Garbage at end | Mark Wheaton | Pro Tools TDM Systems (Mac) | 0 | 04-27-2001 05:22 PM |
