Old 08-31-2010, 11:37 AM
triplex triplex is offline
Question MIDI "program change" send=buffer overflow on target
Trying to send program change from pt midi track to Yamaha DM2000 console results in mixer's midi buffer overflow..
Spying on corresponding midi out with MIDI Monitor utility gives me a lot of randomly mixed midi controller messages being sent including Pan, Channel Volume, controllers 52-56 and others...
When sending program change directly from my midi controller, bypassing PT, everything is fine...
PT 12.8.0
Mac OS X 10.9.5
MacPro2,1 Quad-Core Intel Xeon
16GB RAM
Old 08-31-2010, 12:03 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: MIDI "program change" send=buffer overflow on target
If you solo just the midi track with prg change on it, does it still send all the other random midi information?
Can you view the random midi information on the track with the PRG change info on it? when you go to controllers view does it show this information?
Chris
Producer, Engineer,
www.ukmastering.com
Old 08-31-2010, 12:25 PM
DigiTechSupt's Avatar
Try filtering all MIDI data other than sysex...
Avid Audio Tech Support
Support FAQ
Old 09-01-2010, 01:53 AM
Originally Posted by crizdee View Post
Chris
Yes, I did in solo on a newly created midi track with just 1 program change event created with a pencil tool...
PT 12.8.0
Mac OS X 10.9.5
16GB RAM
Old 09-01-2010, 01:59 AM
It seems I'm able to filter on MIDI input only, isn't?
PT 12.8.0
Mac OS X 10.9.5
16GB RAM
Old 09-01-2010, 03:14 AM
Solved!
There was a MIDI port enabled in PT, which communicates with Yamaha Studio Manager... I've just disabled it under "Input Devices..."
Thank you all guys.
PT 12.8.0
Mac OS X 10.9.5
16GB RAM
Using "Target Notes Via MIDI" with Pro Tools 10 CooperCerulo Tips & Tricks 0 08-13-2013 02:58 PM
D/A pot change "beige" to "blue" corp Pro Tools TDM Systems (Mac) 8 05-09-2011 03:14 PM
Not able to change buffer size? "picture" Jonasfp Pro Tools M-Powered (Win) 3 01-11-2010 04:34 PM
"red target" under RTAS in waves plugs? blizzard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-30-2003 05:37 AM
"Bouncing" . . . . Can I CHANGE The "Default Setting"?? The Zone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-17-2002 02:59 PM
