Old 11-13-2013, 08:52 AM
raff221 raff221 is offline
Default Changing session from 23.976 to 60fps?
I'm mixing a show at edited at 23.976, and final playback will be at 60 fps.
•Is this as simple as changing the TC Rate in Session Setup before bouncing?
•There's no 60fps option. Should I just use 30fps?
•Should I add the .1% pull down?
Thanks
Old 11-13-2013, 05:09 PM
Chief Technician's Avatar
Post Re: Changing session from 23.976 to 60fps?
Yes, though I do not see why you would need to do this.
That depends.
What is the playback source? HDCAM SR? D-5? File-based?
A change in frame rate (23.976-->60) does not affect the audio. A change in frame rate does not change how many audio samples occur in a second.
Old 11-15-2013, 12:03 PM
Soundburst Soundburst is offline
Default Re: Changing session from 23.976 to 60fps?
But doesn't the whole video drift out of sync with the aueo?
Or does the conversion remove some of the frames of the video (or in the case of doubling the FPS. . . double show some of the frames). If you've say 24 FPS. . .and then it's going to 60FPS. . you'd be showing each frame twice?
Are both final videos exactly the same length?
Old 11-15-2013, 01:48 PM
This drift will not occur if the converted media has the same duration as the source media.
If you are going from 24/23.976 to 30/29.97, you need to use 2:3 pulldown if you want the converted media to have the same duration as the source media.
If you do a conform, then you do have to be concerned with pitch shifting and duration. In this context, a conform is the playback of media at one frame rate (23.976) at some other frame rate (25) without actually converting the frame rate or using 2:3 pulldown. Put another way, it's telling someone "Take these frames that should be played back at 23.976 and play them at 25 instead."
If they are, then there should have been no pitch shift.
HTML code is On
Changing Session Tempo RichrdC Pro Tools M-Powered (Win) 6 05-03-2011 08:58 AM
Changing Session Key with AutoTune 5 RichrdC Pro Tools M-Powered (Win) 2 02-05-2010 08:28 PM
Track levels in session keep changing when the session is re-opened. Pred80r Pro Tools TDM Systems (Mac) 3 11-14-2009 01:31 AM
Rename session - changing session name majdi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-18-2008 12:20 PM
Changing Bit Depth for Session KingTor Pro Tools TDM Systems (Mac) 1 04-21-2000 12:46 AM
