Old 04-19-2000, 02:01 AM
Ptrigs Ptrigs is offline
Default Installed ATTO Express protools on my MixPlus, it WONT WORK, HELP
we recently purchased a ATTO SCSI Controller for our MACINTOSH G4 400 for
PRO TOOLS MIX PLUS
the pro tools is working perfectly without the ATTO, but when we installed
the ATTO EPCI-DC, the computer does not wanna start (boot), we tried
installing it on our 9600/200, the same thing happened, we also installed
the ATTO card to our PC Pentium 500, and still it "HANGS" the computer !!
prior to installing the hardware, we carefully read the manual and followed
every instructions, but it still did tnot work
we also did the following on the G4;
we disabled the extension folders and left only the ATTO ExpressPro-Tools
2.2 , and still it did not work
we checked all the cables connected to and from the hardware and made sure
that its terminated and it seems that everything is in order, and we still
cant make it work
we are in deep trouble, it took us a month to order the ATTO, and we surely
cant lose another month, it will cost us a great deal of money ( on lost
clients)
We really need your help !! Need your advice
Markie Diaz
Technical Department
Mixsonic Recording Studio
Manila, Philippines
Old 04-19-2000, 04:33 AM
Altrack Altrack is offline
Default Re: Installed ATTO Express protools on my MixPlus, it WONT WORK, HELP
Try turning off the Atto express extension
in the extensions manager and restart holding down the C key. I've heard from a few sources that the Atto pro tools express does not work with that extension turned on. it should work without it. Also, it depends what your connecting to it. for older SCSI drives and Jaz or zip drives try the Adaptec
power Domain 2930 card. It works great for me. Slao, try it with the C key. Disconnect any modem or USB floppy from the USB ports also. You can connect them after the computer has loaded everything.
Good luck,
Alex
Old 04-19-2000, 07:57 AM
mikejavo mikejavo is offline
We had a very similar experience with an ATTO card that came from the factory. The Termination setting was set to "NONE", not "AUTOMATIC, or UPPER-8". The solution is quite simple, buy two active 68 pin terminators, and place them on the internal connectors. If and when the compurter starts up, go to the Express Pro Tools Application and change the termination to "AUTOMATIC" for both channels. ALSO, make sure you update the firmware to 1.5, which resolves a lot of G4 issues.
If the above does not work, leave the card in the computer and hold COMMAND-OPTION-SHIFT-"D" to bypass the ATTO card, (this worked on the G3), and then update the firmware of the card. You will not be able to access the card at this point, (from the Pro Tools Express Application), so re-boot and see if it worked.
Good Luck.
6.4 wont work on Panther eversince installed Belle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-25-2004 11:19 AM
FAT 32 Drives on ATTO Express ProTools? Mixchump Pro Tools TDM Systems (Mac) 4 09-12-2002 11:56 PM
Two Atto Drives in a chain wont work bartel Pro Tools TDM Systems (Mac) 10 10-29-2001 01:54 AM
ATTO Express ProTools & IDE drives gwprotools Storage Subsystems 1 09-15-2001 09:13 AM
ATTO EXpress on G4 wont work Help Ptrigs Pro Tools TDM Systems (Mac) 7 04-20-2000 11:35 AM
