Old 10-02-2022, 08:41 AM
sw rec sw rec is offline
Default Re: Pluggable dock ok?
Thank you for sharing your wealth of knowledge! I think I can accomplish this with just an HDMI splitter, then, and not a dock. I sure appreciate your help.
Old 10-02-2022, 09:19 AM
its2loud its2loud is offline
I think so as well. No problem. Good luck with the setup.
Old 10-02-2022, 12:46 PM
nednednerb's Avatar
nednednerb nednednerb is offline
By the way, the "OWC Thunderbolt Hub" is technically Thunderbolt 4 where as the "OWC Thunderbolt 3 Dock" is like it says TB3. The "Hub" gives three additional TB4 ports and the "Dock" has 2 TB3 and 1 USB-C.....
I am running both. The "Hub" is stated by OWC to give 3 additional TB4 ports. I have one of those ports using the Apple USB-C Digital AV Multiport Adapter. It runs an old 1080p "smart tv" off the HDMI.
Ahhhh.... looking back at OWC page, the "OWC Thunderbolt Dock" is yet another product with slightly different configuration than those other two. I totally recommend OWC products!
I realize reading above posts too that if I was using the Mini Display Port on that adapter, it would be running that display off CPU rather than GPU? Does anyone know if that is also true regarding HDMI running through a USB-C?
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 10-02-2022, 04:52 PM
bradch00 bradch00 is offline
(It’s terribly OCD of me, but I’m trying to avoid snaking permanent cables around to the front of the MAC.)
Thanks! I thought it was just me....
Pro Tools, Studio One Pro
2022 Mac Studio M1 Max 64GB-1TB NVME
OWC Thunderbay Mini (4TB SSD)
OWC Express 4M2 (4 X 2TB)
Interface: Presonus Quantum
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig)
Old 10-03-2022, 07:06 PM
So, if I do go for a TB 3 or 4 dock, can I indeed derive multiple video outputs from the dock?
  #16
Old 10-03-2022, 08:38 PM
That depends on the Dock.
  #17
Old 10-04-2022, 04:27 PM
OWC just confirmed that their $79.95 TB to dual Display Port adapter will do the job quite nicely, especially using DP to HDMI cables to feed the monitors. Can’t say enough good things about their customer service. Also a huge shoutout to cablesforless.com for equally impressive customer care.
Dock + Raven VS Dock + S1 emankayker Avid Pro Mixing General Discussion 0 11-26-2020 03:30 PM
2 s1 and no dock enough? FilterDecay Avid S1, S3, Dock and Control App 4 05-18-2020 06:04 AM
Suggestion: Users of S3&Dock together: dock fader becomes 5th VCA master fader bassmagnetic Avid S1, S3, Dock and Control App 0 10-01-2016 08:20 AM
T20 dock??? babilonburning 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-18-2000 03:01 PM
