Old 03-17-2018, 02:39 AM
GuitarGiddz GuitarGiddz is offline
Default 'Suspend Automation' enabled, resets all my plugin settings!
Hi Guys,
I've had suspend automation enabled for the whole mix session, and just want to enable it again to write a few simple automation moves. Whenever I de-select 'Suspend' in the Automation window, all of my plugin settings reset, and my fader levels change!
Is there a way to enable automation again, and keep my current mix? (without having to print a load of stems?)
FYI Import Session Data doesn't fix this.
Old 03-17-2018, 04:01 AM
BScout BScout is offline
Default Re: 'Suspend Automation' enabled, resets all my plugin settings!
While still in suspend, select where you want to write you current settings over all of the tracks/regions, then
Edit>Automation>Write to All Enabled
Then take it out of suspend. Obviously, make sure all your plugin parameters, etc are enabled for automation otherwise it won't be written.
Old 03-17-2018, 04:12 AM
Stig Eliassen's Avatar
Welcome to the community.
I don't understand what you are doing. You have automation suspended, have done a static mix, but would like to adjust the suspended automation?
Old 03-18-2018, 03:09 AM
Whilst tracking the song, at some point the automation was suspended (we were using SSL Duality, it's likely that the 'suspend all automation' HUI switch was pressed by accident). We were tracking, so I didn't notice.
Brought the session up in my studio, have a gotten to a point in the mix where I need to automate a few things and then bounce it - but whenever I open the Automation window, and un-suspend automation, all volume, pan, and plugin settings reset to unity values.
I've tried deselecting Volume, Pan, Plugin etc from the automation window, then un-suspending automation, with the same result.
Pro Tools 11.3.1, Focusrite Clarett 4Pre • Macbook Pro - 2.2 GHz Intel Core i7 - macOS 10.10.3 • RAM 4GB, SSD
Old 03-18-2018, 04:11 AM
Have you tried BScouts suggestion?
Old 03-19-2018, 12:44 PM
Hi Stig,
I'm running tools 11.3 non-HD version, I don't think I have that option available.
Best regards,
Alex
Old 03-19-2018, 07:35 PM
Well, you can always clear all automation with ctl-delete.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 03-19-2018, 11:45 PM
Originally Posted by GuitarGiddz View Post
Hi Stig,
Best regards,
Alex
Well, then you have to delete underlying automation, or, set automation to off for desired tracks before un-suspending.
Old 08-24-2020, 07:54 AM
domagtom domagtom is offline
came here to thank you, your advice works for me
Pro Tools | Ultimate, Cubase Pro 10
MacOS Mojave, hMac Intel i9 8core 32GB, Apogee Ensemble TB
Suspend automation lindellsound Pro Tools 11 3 12-08-2015 04:47 PM
Is it possible to save automation just like a plugin settings P,B,S macOS 1 11-24-2012 06:36 PM
Automation, Plugin, write-to-all-enabled, but only for the currently targeted Plugin joachim Pro Tools 10 3 07-11-2012 09:48 AM
Use of Suspend Automation ramu745 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-15-2009 08:18 AM
Plugin Popping with automation enabled? rob shelby General Discussion 1 09-22-2006 03:52 PM
