Old 08-22-2016, 09:54 AM
810 810 is offline
Default Re: What to install of these different softwares 10 11 and 12
I did solve it. Wasapi was a non option for me. As any windows audio based playback engine under the setup tab option was also impossible to use, showing a 6117 error.
I did have asio4all playback engine from the beginning.
Interestingly enough, in my earlier attempt to run Pro Tools 8 on my windows 10 machine, I had gone down the path of Asio4All, and downloaded it--as you may or may not be aware this was a fruitless effort as I found that Asio4All was only available to more recent versions of Pro Tools.
I finally learned just before I got Pro Tools 12 that the earlier Pro Tools, anything before Pro Tools 11 will NOT use more than 3 GB of the computer's RAM. So it became a necessity to upgrade, when I received the same sort of CPU errors on my 16 GB machine that I had always got on my 4 GB, and 2 core machine.
So to cut to the point I did solve the issue of using the RealTek onboard laptop speakers (which includes a 2.1 or 2.0-> 3 speakers... or I could simply run headphones out of the audio jack now which worked real well in a first field test at a children's playhouse this morning haha
Here I made the video to show the procedure to this setup
Asio4All Pro Tools 12 in Win 10 thru onboard spea…: http://youtu.be/deiKagRPCEc
Sent from my HTC One using Tapatalk
best naming softwares feltonisounds General Discussion 1 06-07-2012 02:21 PM
use 002 softwares on MBox? yo man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-05-2003 10:27 AM
Besides PT Le and Logic, what softwares can I use with 001 ?????? lukemaniak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-05-2001 02:40 PM
Compatibility between PTF and others PT softwares alemorais Digidesign Hardware & Software 1 03-24-2001 09:49 AM
DIGI 001 and other softwares dbl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-08-2001 01:56 PM
