Old 09-17-2012, 08:21 AM
crm0510 crm0510 is offline
Default 10.3 Update - Windows shutdown issue has returned. Update at your own risk.
Just FYI for anyone thinking about upgrading to 10.3...dont. After updating from 10.2 to 10.3 the infamous and most annoying windows 'hanging on shutdown' issue has returned. Downgrading back to 10.2 instantly resolved the issue without changing anything else on my system - proving the 10.3 patch is the culprit. Upgrade at your own risk. Thanks again Avid for doing another fantastic job with QA, you guys need a lot of help.
Old 09-17-2012, 10:00 AM
browniespeaks browniespeaks is offline
Default Re: 10.3 Update - Windows shutdown issue has returned. Update at your own risk.
i am unable to replicate this. All systems shutting down normally windows 7 x64
Clifford Brown III
Brown Audio Solutions & Services
www.brownaudio.com
Old 09-17-2012, 11:13 AM
philgrab philgrab is offline
I cannot duplicate this as well. It must be specific to your hardware. Not saying it isn't a bug just saying it's not universal.
Old 09-17-2012, 12:04 PM
Been running like a champ here. Suspect a bad install. Also better to do it as a fresh install, not as an update.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 09-17-2012, 12:58 PM
Dot Dot is offline
yeah, works perfectly fine here too
www.dominicdotokune.com
Old 09-17-2012, 01:15 PM
Raoul23 Raoul23 is offline
Shutting down fine here also. Been fine today was mixing for 3 hours no crashes
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 09-17-2012, 01:23 PM
luken26 luken26 is offline
I have had this problem a couple of times since PT 7.3 but it is shutting down fine for me in 10.3.
Mac Pro (2019) with 3.5GHz 8-core Intel Xeon W Processor, 48 GB DDR4 Memory, 1TB SSD
Catalina 10.15.7
Avid Pro Tools Carbon, Eleven Rack (ERXP 2.0.1), Neve Shelford Channel, SSL Fusion Analog processor, Avid S1 Control Surface, Yamaha Montage 7 (also used as a MIDI controller), Korg Prologue 16 and Adam A7X Monitors.
Pro Tools Ultimate 2021.6, Logic Pro, VEP 7, Exponential Audio. Eventide, FabFilter. iZotope, McDSP, MDW, Softube, Sonnox, Soundtoys, Waves.
Old 09-17-2012, 06:06 PM
Zarabozo's Avatar
Zarabozo Zarabozo is offline
Unable to replicate here. Everything is working fine so far, it's been that way since 10.0.0. I've been on a very heavy/large session for hours for the last 4 days, all day long.
Francisco
The audio world is full of (mainly very expensive) placebos.
Windows 10 Pro 64 Bit
Pro Tools Ultimate (perpetual with active updates/support plan)
RME Fireface 802, Focusrite Clarett+ Octopre, Eleven Rack (ERXP)
Monitors: Yamaha MSP7 and Yamaha HS8S
Asus RoG Maximus Hero Z790 (in a 4U slidable rack mount! )
Intel Core i9-13900k 5.4 Ghz (16 cores / 32 threads)
128 GB RAM G.Skill DDR5 6000 MHz (4 modules 32GB each)
Boot disk: Samsung 980 Pro M.2 2TB
Media disks: 2 x Samsung 980 Pro M.2 2TB in RAID 0 for current work, 2 x Seagate Exos X20 20TB mirrored for archive and backup
Video: PNY/Nvidia RTX 3080 TI with a single 4K display Dell U3223QE 32''
Old 09-18-2012, 10:34 AM
Rob_A Rob_A is offline
No shutdown issues here either. I have noticed some funkyness thow not sure if its 10.3 related.
The setting for the "most commonly used" EQ and compressor in the pref menu seems to get wiped out after a re-start. Anyone else noticed this?
Cheers
Mani
Old 09-18-2012, 11:21 AM
Brandonx1 Brandonx1 is offline
What are the repro steps? I'm able to shut down pt fine and shut down my computer fine. What hardware are you using? Is this pro tools 10.3 hd? I'm on hdx. Everything is running super.
computer shutdown during firmware update on mbox 2 mini agra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-16-2011 07:37 PM
8.05 Update Issue Zeusse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-30-2011 04:24 PM
Eleven Rack Firmware Update issue - Windows Vista felipenoris Eleven Rack 23 03-15-2011 10:05 AM
MIDI keyboard peripherals/windows update issue?? kevin_1657 MIDI 0 05-13-2010 04:40 PM
Windows Update Vs Apples Software Update sunburst79 General Discussion 2 07-14-2007 06:40 AM
