Old 03-13-2003, 06:03 AM
Markk Markk is offline
Default PT 6 OSX - Digital Distortion
After soloing/unsoloing 6-8 tracks individually, When all tracks resume I get enormous digital distortion. Closing/re-opening the file stops this. Anyone else have this problem? Solutions?
Old 03-13-2003, 02:12 PM
DigiTechSupt's Avatar
Default Re: PT 6 OSX - Digital Distortion
Mark,
Are you running SCSI drives? If you're using a supported ATTO card make sure you install the ATTO Configuration Tool found on the PT 6.0 CD. this application installs some required extensions for proper SCSI performance.
Also, make sure all of the drives are formatted with Disk Utility in OS X as HFS+ volumes. We recommend Disk Utility for SCSI drives as well as ATA and Firewire drives.
Mike
Avid Audio Tech Support
Support FAQ
Old 03-13-2003, 02:35 PM
Mike,
Thank you for responding. I am actually running on Firewire:
Mac Dual 500
OSX 10.2.4
1 gig ram
Two internal HD (one with Pro tools 6.0)
One external 80 gig Glyph Firewire
HD 3
192 i/o
Does that help?
Old 03-13-2003, 03:05 PM
Mark,
Did you already format your firewire drives with Disk Utility on X? If not, backup your firewire drive and reformat it with Disk Utility as an HFS+ volume. Disk Util will also let you partition firewire drives unlike Erase Disk in OS 9. Let me know how it turns out.
Mike
Support FAQ
Old 03-14-2003, 12:38 PM
Doug Rider Doug Rider is offline
Mike,
I have a client with an HD3 system PT 5.3.1 on a dual 1 gig running on OS 9.2.2. They have 4 hot swap ultra wide SCSI drives (w Digi's ATTO UL3D HBA) in a StorCase enclosure formatted with the ATTO Application. Everything is currently working well.
On a different internal IDE drive, they have OSX 10.2.4 installed. They are about to install PT 6 on that drive only.
Will they have to reformat their 4 hot swap drives with Disk Utility in OSX to be able to properly use the SCSI drives with PT 6 or will they operate under PT6 as is without formatting?
They will be rebooting and switching back and forth between PT5 on OS9 and PT6 on OSX.
Thanks.
Doug
Odd digital distortion SoundtrackArcade Pro Tools HDX & HD Native Systems (Mac) 3 09-11-2012 01:51 AM
digital distortion ventjw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-06-2005 04:20 PM
Digital distortion STUDIO A 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-18-2004 06:00 AM
Digital Distortion with 001 Nick Rogers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-29-2004 12:09 AM
digital distortion qgrm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-24-2004 10:23 AM
