Old 08-30-2006, 02:13 PM
SHIRK SHIRK is offline
Default Waves IR-L stops passing audio???
I'm running PT v7.1cs9 on an HD3 (non accel) / G5 Dual 2.5GHz / 3.5 GB RAM / Waves Diamond TDM v5.2 (WUP is up to date)
Every now and then when I have a Waves IR-L (full) plugin on a stereo Aux track, it kind of goes to sleep. Stops passing audio all together. Making the plug-in "inactive" then reactivating it brings it back ot life. Anyone had this problem? Fixes?
Thanks,
Steve
SHIRK
www.shirkmusic.com
www.hearya.com
MacPro 12core 2.66Gh Westmere
OSX v10.7.5
20GB RAM
1x HDX
2x HD i/o 16x16, 1x Digi192 8in/16out
PT HD v10.3.7
Old 08-30-2006, 03:23 PM
thierryd thierryd is offline
Default Re: Waves IR-L stops passing audio???
I've seen the same thing happen on our HD(5) system with a Core, Accel and 3 HD process cards, using PT7.1.cs9 and OS10.4.3
I stopped experimenting with IR-L after these phenomenon and the fact that apparently one can't automate the impulses during a mix. I want to be able to change the impulse while I'm mixing a 50 minute tv drama episode and apparently only 3 parameters could be automated and not the impulse. Am I missing something or is this a limitation of the Light version?
Greetings,
Thierry
http://www.a-sound.com/
Old 08-30-2006, 07:12 PM
c-tone c-tone is offline
Check out this thread
Could be the same issue as what you are having.
www.clifnorrell.com
Old 08-30-2006, 09:02 PM
mixx mixx is offline
slide the plug in insert into another insert position ahh umm other than its orig location[ie 1-6] it will clear up and be cool
Ampeg SVX 1.1.3 stops passing audio Dizzi45Z Pro Tools TDM Systems (Mac) 25 07-30-2012 03:08 AM
Left Channel stops passing audio montezuma 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 04-07-2010 08:13 AM
structure free stops passing audio zakco Pro Tools TDM Systems (Mac) 4 07-14-2009 10:58 AM
Waves SSL / API / V-Series TDM Not Passing Audio JSR Pro Tools TDM Systems (Mac) 2 10-09-2008 12:33 AM
core audio conects , but no audio passing threw audiomania Pro Tools TDM Systems (Mac) 2 08-23-2006 08:41 AM
