Old 12-21-2003, 08:46 PM
Angus202 Angus202 is offline
Default Can the 001 be unplugged???
dumb question, but better safe than sorry... Can the DIGI 001 be unplugged from the computer (while the power is off) and the computer used without damaging the PCI card? I'm moving my system and dont want to lug the rack with my 001 in it just to use the PC when I'm not using protools. I only ask because I used to have a Delta 1010 rackmount and it needed to always be connected to the computer or the card could be damaged.
Thanks,
-Ryan
Old 12-21-2003, 09:42 PM
Mr_Seven Mr_Seven is offline
Default Re: Can the 001 be unplugged???
Turn power off first (you knew that but worth repeating)
Yes both pieces can operate independently of each other but with out complete functionality of course.
the PC will still run protools without the break out box attached and the optical and spdif works.
Just don't connect/disconnect while powered up. Did I say that already:)
Darren Valen
Cyberdream Studios
Old 12-21-2003, 10:29 PM
3JDamon 3JDamon is offline
And don't hot-swap it either
can Mbox Pro 3 be hot swapped / hot plugged / hot unplugged? marcnyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-20-2011 05:11 PM
Should The Mbox 2 Pro Be Unplugged After Sessions? Roper Band 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-07-2009 07:36 AM
Computer won't hibernate unless MBox is unplugged emzine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-11-2005 10:29 AM
vocals w/ unplugged electric? fadein 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-08-2004 09:11 AM
Mbox unplugged? Kodiak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-26-2003 06:54 PM
