Old 12-20-2003, 06:00 AM
fredsparky fredsparky is offline
Default Survey Favorite Plug-ins on Master Fader and Aux
Hi. I was wondering what plug-ins you all are using on your master fader (MF)(now that's an acronym!) and aux channels- and what order they are in. Is it better to add reverb and delay fx via sending to aux? Is it better to use compressors and limiters on the master? So if you don't mind, will you list some of your favorite plugs in your aux and master fader signal chain?
Example for response:
"Aux- (stereo or mono) abc compression, reverb, then delay:
MF- (stereo) L2, abc reverb, then xyz plug."
Thanks much and have a great and SAFE Christmas and Chanukah Holiday!
FS
July
MP3's
Old 12-20-2003, 06:14 AM
feliponk's Avatar
feliponk feliponk is offline
Default Re: Survey Favorite Plug-ins on Master Fader and Aux
Hi Fred: I always use the Aux Tracks for FX like Reverbs or delays, in the master fader I didn't put anything that an analyzer, like Waves PAZ, because I do compression on every channel who need it, and eq. in the same way. Whe I do mastering, I put comp, eq. stereo expansion and dithering in the MF, and obviusly the analizer.
My best plugins are:
1 Waves (really a Swiss blade)
2 Bomb Factory (cool, warm sound)
3 Antares
4 DUY
5 everything else in no particular order
Take care
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
http://felipousismix.wix.com/felipousismix
Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins
Old 12-20-2003, 09:58 AM
Mr_Seven Mr_Seven is offline
Aux: Verbs, delays, sometimes a sans amp
Master: only a L1 set to medium so I get a feel for how it's going to sound after mastering. I'll toggle that often to hear with no limiting. I do all my mastering outside of PTLe with T-Racks! So I bounce with the L1 inactive. If you bounce to CD then use maxim or a dithering plug on the master.
Darren Valen
Cyberdream Studios
Old 12-20-2003, 07:32 PM
OK Cool! Thanks much!
FS
July
MP3's
Old 12-21-2003, 07:16 PM
where02190 where02190 is offline
Be awarre, themaster fader insert is POST FADER, and any change in the master fader position will change the level into the plugin.
My favorite part about the Avid Survey. ronwasserman Pro Tools 10 41 12-06-2011 07:38 PM
master fader plug-in delay? hyp0static 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-08-2007 08:46 PM
Favorite stereo EQ for use on master fader fuzzles Pro Tools TDM Systems (Mac) 0 04-12-2005 11:47 AM
What's Your Plug-In Chain on the Master Fader??? CraigD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 22 04-14-2004 10:12 PM
plug-ins mute master fader seromaz Pro Tools TDM Systems (Mac) 1 11-17-2000 08:46 PM
