Old 03-20-2018, 05:08 AM
Burstbucker Burstbucker is offline
Default Put in a bunch of hours last night on a session and now it won't open!
I put a lot of time last night on a tune that I've been working on for months now and I just put the final touches on it and saved it. Excellent! Right?
Well this morning it just hangs there when it's "restoring tracks". Aargh.........
It always seems to get finicky at the very end, after all that work.
I searched for this problem and it could be a plug-in problem but I always use the same plug-ins and they don't usually cause me any problems. I know that I added a bunch more automation to my session last night, I wonder if that's part of the problem.
When the tracks are being restored it pretty much gets all the way to the last track and then just hangs there doing nothing.
I will try again tonight after work. My buddy was going to come over and help with the final mix down but we will probably spend the night just trying to get this darn thing to open.
It's times like these that make me question why I bothered getting into home recording.
Sorry for the rant.
Dell i7-6700k @4.00 GHz 64-bits with 24 GB RAM, Windows 10, Roland Duo-Capture EX, Pro Tools 12.7.1
Crucial MX300 525GB SATA 2.5 inch
SATA III SSD
1 TB spinner drive 7200 RPM
Old 03-20-2018, 05:29 AM
Default Re: Put in a bunch of hours last night on a session and now it won't open!
I have earlier versions of this session from a week ago that open up just fine, the same plug-ins and everything but over the last few days I have added a few more tracks with extra automation, etc..... And before I saved this session last night I played it back many times over and it worked perfectly.
I'm going to try plugging my iLok into a different port and if that doesn't work I will try opening the session with the plug-ins disabled.
I hope I can retrieve what I did last night, I could live without this kind of hassle really.
SATA III SSD
Old 03-20-2018, 05:36 AM
Is the session on your spinner or ssd? Try it on the ssd and see what happens. I'm wondering if the data path is getting clogged somehow and the spinner can't get data to the rest of the system fast enough?
Jack
QAPLA!
amagras amagras is offline
If none of that works you can always import session data to a blank session but opening with the plugins inactive should work. Good luck!
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 03-20-2018, 05:50 AM
A big thank you for the replies guys!
I have my sessions stored on a 1TB spinner drive and Pro Tools and all plug-ins are located on a SSD which is my C drive.
SATA III SSD
Old 03-20-2018, 06:03 AM
Try moving the problem session to the ssd. If it still barfs then I'd say the session somehow got corrupted.
Jack
QAPLA!
Old 03-20-2018, 06:22 AM
Yeah I will try moving it to the SSD if nothing else works but I was told before that it's better to have the sound files and PT on separate drives.
Maybe I'll need to invest in another SSD for my sound files?
I was hoping that the 1 TB spinner drive would be good enough.
SATA III SSD
Old 03-20-2018, 06:25 AM
And if the session somehow did get corrupted, how would I go about uncorrupting it? If that's even possible.
Instead of moving it to the SSD could I send a copy of it to the SSD?
SATA III SSD
Old 03-20-2018, 07:13 AM
Raoul23 Raoul23 is offline
Have you tried this^^^^^
This has saved me many of times
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 03-20-2018, 07:27 AM
No I have never tried importing session data into a new session. But it kind of looks like I might have to learn how to do that.
I'm no genius when it comes to computers so everyday presents a new challenge. I wish that it could be easier. Sort of takes all the fun out of it.
SATA III SSD
Importing session data adds a bunch of automation points! DJ Hellfire Pro Tools 10 13 03-11-2013 08:45 AM
PT7 HD3 - Delay before Playback Starts - after session open for a few hours warrickmarais Pro Tools TDM Systems (Mac) 8 01-14-2009 02:55 PM
OS X 10.4.4 .PTLE quit in my session last night. Ty Ford 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-09-2006 12:12 PM
when i open pt a bunch of expired windows appear eddybertrand Pro Tools TDM Systems (Mac) 1 05-29-2001 12:44 AM
late night session in progress please help tomcat Pro Tools TDM Systems (Mac) 7 10-13-1999 09:19 PM
