What is best way to cancel the PC NOISE?
Hi All,
I have home studio (recording, mixing and mastering in the same room) , I have Antec - DF-85 case which is noisy. What is best way to cancel the PC NOISE? Thanks AK |
Re: What is best way to cancel the PC NOISE?
Well I have no idea what a Antec - DF-85 is, and really I do not care, i won't be googling it.. perhaps some more specific's. Like is it a fan?
I'm using a B-Quiet powersupply. REALLY Quiet !
Also the bigger a fan the less noise it will make.
Philippe Meiresonne (Belgium) http://www.pm-mastering-studio.com SYSTEM 1 : Main recording - HDX MAC Pro 2023 M2 Ultra Running Sonoma 14.4 ProTools Ultimate 2024.3.1| 1xHDX Card | Mac Pro M2 Ultra 128Ram 2TB|2x PRE |2x Audient PRE 880| 1x Avid 96 |1x Avid 192 I/O 16/16 Analogue | 1x Avid HD I/0 16/16 Analgue | Avid MTRX Studio + Thunderbolt 3 Interface Midi I/O | D-Command ES +16 fader Pack | Xmon | Eleven Rack + Dolby Atmos 7.1.4 Surround Adam S3H speaker System System 2 : Project System - ProTools CARBON Running Sonoma 14.4 MacStudio M2 Ultra |64 GB RAM | ProTools 2024.3 Ultimate/Studio | SSL2+ | AVID S1+DOCK + ProTools|Carbon + ProTools|Carbon PRE System 3 : Dolby Atmos Renderer Running Sonoma 14.4 MacMini M2 Pro |16 GB RAM | Avid MTRX Studio (Thunderbolt3) |
zsarbomba, you are the rudest person. You take the time to write a post, but not to investigate. He cant be more specific than that, he gave you the model of the computer. Thanks for beeing useless
Now akhafaji regarding the computer issue, you have 2 options, 1 could be to get an extender for keyboard, mouse and monitor and put the computer on another room, if possible. The other one is to get a silent rack, is not cheap, but is very effective Hope that helps
I used to be insecure...now I'm not really sure |
1) Record some "silence"
2) Invert phase and add to tracks as needed 3) Profit
- Knowing nothing is better than knowing it all - |
Water cooling kits will also tame fan noise in a PC.
water cooling def. helps... though as mentioned above cases with bigger fans are
much quieter... i have seen cases which have the rear panel up top and 3 rather hefty (at least 140mm} fans on the bottom shooting the air straight through the case and out the top... man i tell you, barely hear the damn thing at all.. at the end of the day, an enclosure is a great tool as well, ...just not a cheap one at that... i'm running an ANTEC water cooling solution, with ultra quiet german COUGAR VORTEX fans on push pull, they have done an incredible job of dropping my core temps by at least 10 deg., and i def. cant hear them.. my only issues right now are surrounding the front fans, they came with the case... so i'm probably gonna upgrade those down the line as well.. cooling is very important though, so my case runs 6 fans, one of 'em being 200mm on the side door, the rest are all 120mm, which is a bit of a pain..
kickin' at the darkness 'till it bleeds daYlighT
Not sure if this is an option for you, but you could always locate the PC in the next room and just route the relevant cables through the wall. Head to Monoprice, buy a set of 15 foot cables (DVI/USB/Firewire/etc) and then enjoy your completely silent workspace.
Why did you even bother to type this? It's not always possible, but I agree that putting it in another room is the best way. When I built my studio I designed a machine room into it to hide the computer and the reel to reel machines. Other than that, if you're crafty enough, built a box lined with foam and put her in there, just leave enough space to it can still cool. Wont get rid of all the noise, but it will cut down on it.
GIGABYTE X58A-UD3R, INTEL CORE i7 960, NVIDIA GEFORCE 8400GS, WIN 7, MOTU 896mk3 HYBRID, PT 10.3.2 |
Can't cancel bounce | DontLetMeDrown | Windows | 21 | 04-26-2011 10:52 PM |
cancel order. | helbo512 | General Discussion | 2 | 02-28-2009 01:26 AM |
esc key does not cancel recording in PT 6.7 | beggehorn | Pro Tools TDM Systems (Win) | 2 | 11-08-2004 11:15 AM |
DSP Manager needs a CANCEL button!!! | uno1234 | Pro Tools TDM Systems (Mac) | 10 | 04-18-2003 09:42 AM |
Cancel the Fades! | Poolbath1 | Tips & Tricks | 3 | 03-08-2001 02:33 AM |
