Old 07-05-2011, 12:06 PM
chopin88 chopin88 is offline
Default Pro Tools 9.0.3 CPU Overload
I've recently updated to PT 9.0.3 and now have major problems with the Buffer Size running over the limit even when there are no plugins selected. Is there a fix for this issue?
Thanks!
AP
Mac OSX 10.6.8
Old 07-05-2011, 12:20 PM
cocamycola89 cocamycola89 is offline
Default Re: Pro Tools 9.0.3 CPU Overload
I am also experiencing some major problems with this.. :-( running a pretty small session compared to my norm atm and now this is starting to become a real issue. Anybody know anything?
Old 07-05-2011, 12:27 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Need more info. Computer, RAM, # of cores, where you have set % of memory, stuff like that.
What troubleshooting have you done already?
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 07-05-2011, 04:02 PM
Hey Park!
I am running a Mac Pro
Duo Core
2x2.66 GHz Intel
20 GB Ram
Pro Tools 9.0.3
Profire 2626
80% set memory
I've adjusted my buffer settings, nu,beer of processors and double checked settings for my plug ins. Unfortunately, nothing has worked. Any help is greatly appreciated as a fix is needed ASAP! Thanks!
Alvin
Old 07-05-2011, 04:35 PM
Tom Swift Tom Swift is offline
I get this same thing all the time.
I keep getting the "overload error" -6101 message when i try manipulating plug ins while music is playing. Very frustrating when i'm trying out EQ settings for example.
CPU shows a load of only %15 or so . i can stop ,adjust and THEN play-but can do almost nothing while tools is playing.
Any ideas? (this doesn't happen with my other DAWS.)
Quad 2.66 MacPro
10.6.7 snow leopard
PT 9.03
macPro quad 2.66
PT 9.03
Happens with any buffer setting
Old 07-05-2011, 06:47 PM
bradch00 bradch00 is offline
I had 9.0.3 upgrade issues; first thing I did was trash the prefs and deleted the databases. No problems since. I would try that.
chopin88 (Alvin) you mention 20GB RAM, that seems like an odd number to me.
What configuration is it in? There's lots of info on the board about people having trouble using mismatch RAM sets.
Pro Tools, Studio One Pro
2022 Mac Studio M1 Max 64GB-1TB NVME
OWC Thunderbay Mini (4TB SSD)
OWC Express 4M2 (4 X 2TB)
Interface: Presonus Quantum
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig)
Old 07-05-2011, 06:54 PM
Originally Posted by chopin88 View Post
Hey Park!
Duo Core
2x2.66 GHz Intel
20 GB Ram
Pro Tools 9.0.3
Profire 2626
80% set memory
Alvin
Just checking -- a Mac Pro or Mac Book Pro? 20GB or 2GB? How many disk drives do you have and what is their brand/model/interface type/rotation speed/etc.. What drive are you recording to?
Thanks
Darryl
Old 07-05-2011, 07:55 PM
Hey Darryl,
It's a Mac Pro Desktop
16 GB Ram
3 Internal Drives
1 External Drive that i record to.
Thank you for your help. Trashing the preferences was a huge help!!
Alvin
Old 07-06-2011, 10:04 AM
Some things:
"Make sure that you do not have FireWire networking enabled in your Network control panel in OS X. Go to: Apple Menu > System Preferences > Network and, from the 'Show' drop-down box, choose Network Port Configurations and uncheck any boxes next to 'Built In FireWire', then click 'Apply Now' and restart your computer."
"DAE Error -6101 with the ProFire 2626.
This is a known issue in Pro Tools M-Powered 7.4cs3 (Mac OS X) with M-Audio's ProFire 2626. Workaround: Change buffer setting to 256 or higher"
"DAE error -6101, -6085, -6081, -6096, or -1115 when using a FireWire interface with Pro Tools.
PLEASE NOTE THAT YOU SHOULD ALWAYS TURN OFF YOUR FIREWIRE INTERFACE AND COMPUTER BEFORE CONNECTING OR DISCONNECTING THE FIREWIRE CABLE! FAILURE TO DO SO MAY DAMAGE YOUR EQUIPMENT!
This may be caused by a poor firewire connection or high traffic on the 1394 bus. Please check the following:
1. Is the firewire device plugged directly into a firewire port on the computer, or is it connected to a hub or display with additional firewire ports?
Many computer displays can connect to a firewire port on the computer, and have built-in firewire ports for convenience. Pro Tools LE and M-Audio interfaces must be plugged directly in to a firewire port on the host computer. Usage of a hub or port repeater can introduce errors.
2. Have you tried all available Firewire ports on the computer?
Mac Pro and G5 computers have firewire ports on both the front and rear. On Mac Pro systems, Pro Tools firewire interfaces usually perform better on the rear port. On G5s, the reverse is usually true. If you run into problems, try all available ports.
3. If using a Windows-based system, does your computer have a supported firewire controller?
If you look at the Device Manager, under the heading "IEEE 1394 Bus Host Controllers," do you see a Texas Instrument-branded host controller? If not, your firewire controller in untested and may cause problems with Pro Tools. For a list of supported firewire controller cards, visit this link.
4. If you are using a firewire hard drive with your system, please make sure you are conforming to the recommended configurations and specifications on these pages:
Hard Drive Requirements - Mac
5. If you are using other firewire devices on the computer (for instance a Mojo or other video peripheral), it may help to connect these to separate buses entirely. To accomplish this you must use one of the supported firewire adapter cards covered here:
Firewire Cards for Mac"
Park
Old 07-06-2011, 11:57 AM
orbro orbro is offline
Mac OSX 10.6.8 is not qualified for Pro Tools systems and should be the first thing that you eliminate when troubleshooting this issue. OSX 10.6.7 and PT 9.0.3 are the latest versions that are qualified. You still may run into the overload error though as people are reporting the same problems with the 2626 and PT 9.0.3
Pro Tools 10 CPU Overload trebot000 Windows 30 02-28-2013 11:02 AM
pro tools cpu overload? MTaborda macOS 3 10-29-2012 10:05 PM
Please help me with pro tools m audio 8 cpu overload!!!! Oboist Pro Tools M-Powered (Mac) 40 01-21-2011 08:21 AM
Pro Tools 8.0.3 on W7 x64 - CPU overload azirkin Pro Tools TDM Systems (Win) 9 12-28-2009 06:14 AM
Pro Tools 8 M-Audio CPU Overload Abby B Pro Tools M-Powered (Mac) 1 02-23-2009 11:45 AM
