Old 03-27-2010, 05:52 PM
GtrDude GtrDude is offline
Default Testing for secons HD card
I have just installed PT 8.0.3 HD2 on a new computer with Win7 64 bit.
I was running XP before.
I would like to ask how I can test that PT is reading both cards?
They're both PCIe.
When I go to Setup>Hardware and under Peripherals window I only see one card.
It says "HD Core PCIe #1"
Is there a way to verify this?
Thanks
GD
Old 03-27-2010, 07:16 PM
Default Re: Testing for secons HD card
I suppose if DigiTest registers it, it must be there.
True?
GD
Old 03-28-2010, 12:58 AM
Ghengis Ghengis is offline
Look in the System Usage Window, it will list the number of DSP cards the system has found. Windows pulldown/system usage. You will have to open the window up as PT doesn't remember the window size.
cya
Ghengis
Old 03-28-2010, 08:42 AM
Thanks for that Ghengis.
Under TDM I have:
Voices Allocated; 2/48
Time Slots Used; 7/512
Under Core PCIe #1:
HD Engine; 100% (all read, don't know if this is OK)
StereoMixer24; 14
Under AccellPCIe #1:
Everything is blank
Note I don't have an active session on.
Does this look OK to you?
Thanks
GD
Old 03-28-2010, 01:41 PM
If it's listing a 2nd PCIe Card then it looks registered. Looks like in playback settings you are only set to 48 or 32 voices with 1 dsp card. Goto playback settings and change the playback to be 96 voices/2 dsps.
Then create a new session, create a whole stack of tracks (eg 48), then if you option+click on an insert you can create a whole lot of plugins. This will start to fill up your second DSP card. All looks Ok!
cya
Ghengis
Old 03-28-2010, 06:41 PM
Thanks for the tip.
I did exactly what you said.
GD
testing accel card pie55 Pro Tools TDM Systems (Win) 20 08-21-2012 01:29 AM
OT:Testing 1,2,3 Bazzle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-04-2004 03:31 PM
Mic Testing - FYI Kenny Gioia Tips & Tricks 52 12-04-2002 01:43 AM
Testing, Testing, Testing 24-bit Pro Tools TDM Systems (Mac) 10 03-28-2002 07:46 PM
Testing your DAW (you may want to know this) Drastikpup1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-22-2001 03:26 AM
