Old 05-30-2012, 12:20 PM
northridgedave northridgedave is offline
Default iMac and 002r problem, pt10.2
I have a new iMac running 10.7.4, pt 10.2 and all current driver updates. The green status light on my 002r keeps blinking and the hardware doesn't link up. This machine is boot camped and the 002r and pt run fine on the windows7 partition. I also have an new mbox mini (NOT connected at the same time) that runs fine on both partitions. Anyone else having a similar problem? The easy fix of course is to only run on the w7 partition but i'd like to run on the mac side.
I am new to Mac so it could be something simple that I have overlooked.
Any help gratefully accepted.
Thanks.
Dave
iMac i7
8gb internal
os x 10.7.4 and win7 dual boot
digi 002r and or mbox mini
many removable drives
Old 06-02-2012, 02:11 PM
Default Re: iMac and 002r problem, pt10.2
Found a solution in an earlier post:
Big Thanks to Paul Cavins.
Holding down "n" while booting pt brings the 002r on line.
Does any one know what the "n" on boot-up actually is?
The semi-geek in me is really curious.
Thanks again,
Dave
Old 06-02-2012, 02:48 PM
Tweakhead Tweakhead is offline
Originally Posted by northridgedave View Post
snip...
It allows you to change the playback engine from your Avid hardware to your internal mac audio I/O ... or any 3rd party hardware.
Old 06-02-2012, 03:55 PM
Thanks
PT10, Imac and 002 problem lonestarparis Pro Tools 10 4 11-02-2013 04:55 PM
IMac/PT10 Mix Window? zixis9 Pro Tools 10 3 05-20-2013 06:20 AM
Do I need an Mbox with PT10 and an iMac? CRD Pro Tools 10 6 03-03-2013 07:39 PM
Optimizing PT10 with my iMac World Spirit macOS 9 02-19-2012 07:41 AM
PT10 - iMac Questions auralicious Pro Tools 10 1 02-02-2012 06:36 PM
