Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 04-15-2015, 03:35 AM
Matt Darcy Matt Darcy is offline
Default Apogee Ensemble Thunderbolt - end user experience
Has anyone actually tried the Apogee Ensemble Thunderbolt interface with pro-tools 11.
Based on a useful tip on this forum I think I'm going to plump for one, however has anyone ever used one, does it just appear in the pro-tools input list on the fader options the same as say my 003 rack did ?
Have you tried it using thunderbolt or firewire ?
any experience would be really appreciated.
Old 04-15-2015, 05:07 AM
Default Re: Apogee Ensemble Thunderbolt - end user experience
I don't have one - looking to go for one when finances permit - but here's a couple of things you should know. First it's Thunderbolt only - no Firewire. Second you're going to need to be running a minimum of OSX 10.9.3 or greater.
Not sure what you mean by will it appear in the PT input list on the fader options the same as your 003R. It's going to have completely different I/O than your 003R so it will of course show up different.
Jack
QAPLA!
Old 04-15-2015, 05:17 AM
bought one - thunderbolt only isn't a problem, I'm running 10.10, so thats fine too,
going to be keen to see how this works, I suspect I'll need advice from the more seasoned on the forum
Old 04-16-2016, 07:27 AM
RicoRoss's Avatar
RicoRoss RicoRoss is offline
Still learning how to get my **** going on Pro Tools. But the new Apogee Ensemble Thunderbolt is pretty damn good. Easy to use, seamless compatibility with Pro Tools 12.5 and El Capitan. The sound of the mic preamps is ^$*#ing glorious. I have not yet had the opportunity to try the Hi Z inputs and when I do, I'll let you know how they stack up.
I have only one minor issue. The two headphone outputs are a little noisy. I am using AKG K240s headphones which are notoriously low in level, but clean, and I am hearing some noise at the levels required for drummers to hear their monitoring in the cans.
Old 04-16-2016, 02:02 PM
I'd say the noise in the cans is probably more due to those AKG240's and not the headphones of the Thunderbolt as those outputs are the cleanest in the industry save for maybe something from Grace.
Oh - you would make a better impression if you don't use foul language. There's a time and place for such but this isn't it dude.
Jack
QAPLA!
Old 04-16-2016, 04:46 PM
RicoRoss's Avatar
My apologies for the language. I am new to the culture embedded in this forum. Forgiveness, please.
Old 04-17-2016, 01:49 AM
RicoRoss's Avatar
After some investigation I have locate the source of my noise. With faders up on 5 audio channels, 3 aux's (effects), an aux master (for compression), a master fader and transport stopped I am getting some "in the box" noise. There are a few plug-ins on each channel and I am guessing that it is mostly these that are the cause.
Sorry Apogee for blaming your HP sends. They are as you suggested, musicman691, close to Grace.
I do not think I am being wimpy with my levels.
Is this normal for Pro Tools? Or am I doing something bad again?
13" Retina MacBook Pro, macOS Big Sur 11.6
Pro Tools 2021.12
Apogee Ensemble Thunderbolt 2
RME Octamic II
UAD Octo Satellite
Old 04-17-2016, 08:34 AM
Drew Mazurek's Avatar
what plugs? Many that emulate analog gear have noise inherent in them.
www.drewmazurek.com
Old 04-18-2016, 11:30 AM
gthm's Avatar
gthm gthm is offline
Gentlemen,
Shouldn't this thread be in the Third Party Interfaces section? Can it be moved there? Not sure how that works.
There should be an Apogee Ensemble Thunderbolt appreciation thread in the Third Party Interfaces sub-forum. We can talk about track count on different Mac setups, any issues, etc.
Have you guys noticed that there are only 4 threads total about the Ensemble Thunderbolt, if you search the DUC (since late 2014)? I thought there would be more interest in the ET!
So, can this thread be moved to the Third Party Interfaces section or should I start a new one? Let me know!
Pro Tools 2024.3
macOS 14.4
iMac (24-inch, M1, 2021)
(16GB RAM, 1TB SSD internal)
Samsung T7 x a few
Samsung 980 Pro x 2 (in Acasis TB/USB 4 enclosures)
Apogee Ensemble Thunderbolt (my hero)
Old 04-18-2016, 12:21 PM
RicoRoss's Avatar
Thanks Drew,
Yes.... VComp was the culprit
Re: Moving the thread. Is that a job for a moderator?
Pro Tools 2021.12
RME Octamic II
UAD Octo Satellite
Apogee introduces new Ensemble Thunderbolt nst7 Third Party Interfaces 25 09-22-2016 02:13 AM
Protools 9 and Apogee Ensemble Thunderbolt smilch Third Party Interfaces 1 12-13-2014 11:03 AM
Will Firewire to Thunderbolt Effect my PT Experience? ianbee macOS 1 08-28-2013 01:44 AM
Anyone have any experience with a Thunderbolt Sam C macOS 4 12-02-2011 05:07 PM
DIGI 003 + Apogee Ensemble + Apogee Big Ben = World Clock marcioguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-11-2011 02:24 PM
